In Areas With A High Water Table, - Excavation & Site Work - Contractor Talk
Old 05-03-2015, 12:36 PM   #1
GettingBy's Avatar
Rewards Points: 6,486
anybody do a totally waterproof basement, either with
a membrane external to the basement or
a welded steel hull or
a prefab concrete shell?
No sump pump or drainage necessary?
GettingBy is offline
Old 05-03-2015, 12:44 PM   #2
dayexco's Avatar
Rewards Points: 20
Re: In Areas With A High Water Table,
I think depending on elevation of static water table in relation to basement floor elevation if you don't have enough weight on it you may create a submarine. .
Personally I think it would be better to take measures to lower water table.
dayexco is offline
The Following 2 Users Say Thank You to dayexco For This Useful Post:
GettingBy (05-04-2015), rino1494 (05-03-2015)
Old 05-03-2015, 01:52 PM   #3
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Without proper drainage, static water pressure could pop you basement slab. IMO, there is no totally waterproof basement.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
Old 05-03-2015, 05:29 PM   #4
GettingBy's Avatar
Thanks. This will not be easy. Reading these may put me to sleep.
http://www.dtic.mil/dtic/tr/fulltext/u2/a225108.pdf
and
http://www.google.com/patents/US5845456
I'm thinking the weight of the house will keep a waterproof basement down, but a 900 sf, 8' high basement would displace 225 tons of water.
Do houseboats have basements?
Sounds like piers or a sump pump or drainage or a very heavy house or helical piers keeping the basement in the basement.
Old 05-03-2015, 05:32 PM   #5
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Some houses should not have basements----you will be running pumps 24/7 --and bailing the place out every time you have a pump failure---
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
Old 05-03-2015, 06:34 PM   #6
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
I agree with mikewoods. When we built my mothers house she wanted a basement. We did a test hole for the septic system and found the water table only down less than two feet. Sorry ma, no basement. There are people close to her who have half basements below grade. Every spring they are running pumps steady to keep the basement from flooding. Sooner or later the pump will fail or the hydro will go out when your not home. Bad by design. Once something floods it very hard to dry it out properly. Mold would be an issue. We did a full frost foundation then a slab for my mom. We raised the yard two or three feet.
muskoka guy is offline
The Following 3 Users Say Thank You to muskoka guy For This Useful Post:
dayexco (05-03-2015), GettingBy (05-04-2015), Railman (05-05-2015)
Old 05-03-2015, 11:26 PM   #7
dayexco's Avatar
Rewards Points: 20
you can buy a LOT of placed fill on a residential lot for 10k....raise the house up to proper elevation and not worry about it.....
OR!!!...place the proper drainage system around the home...
OR!!!...have a pump fail and do $30k damage to your finished basement....
never could figure out why anybody would ever consider putting a structure into a known water table...or with soils that are so saturated/impervious..they've got no where to go but into the basement.
water will take the EASIEST route...gravity dictates that. hole or crack in the wall/floor, it's coming in.
dayexco is offline
GettingBy (05-04-2015), Rio (05-05-2015)
Old 05-04-2015, 08:43 AM   #8
GettingBy's Avatar
It seems what saves our basement is the sump water never rises to the floor surface level and is most of the time totally dry.
We probably never needed a sump pump but it came with the house and when it failed I put in a new 1/6 hp which should be able to handle a 1 GPM refill rate raised 7'.
I read the long document.
The books mentioned at the end may have gone into later editions but overall I'm not optimistic about waterproofing.
Even for a perfect system, schedule pressures will possibly prevent following the install instructions to the letter.
Maybe a precast impermeable concrete shell with 1' thick walls could do for a waterproof basement but who does this, if it could be done?
Thanks, folks. . .
Old 05-04-2015, 03:22 PM   #9
Rewards Points: 558
I know of one in town a contractor friend of mine did. For some reason they had to have a basement and they lived right beside the river. I think my buddy told me they had to pour the basement floor three feet thick just to act as a weight to keep the house from floating up. Recipe for a large bill in the future WHEN it floods. Would not even consider a basement in a high water table situation.
Old 05-04-2015, 07:56 PM   #10
Box Builder
Morning Wood's Avatar
Rewards Points: 10,298
That happened here on a job. Dug hole poured footers walls and slab. Framer came to frame and everything stopped. Apparently the thing had floated up. Ended up hammering everything out and the poured a massive thick slab and added some weird dewatering system. Happened to a builder who is not loved, so i don't think alot of people cared much.
Morning Wood is online now
Old 05-05-2015, 12:09 AM   #11
Designer/Contractor
Rio's Avatar
Rewards Points: 526
No, but they have bilges.
Rio is offline
Old 05-05-2015, 01:52 PM   #12
GettingBy's Avatar
Bilge pump = sump pump
The Following User Says Thank You to GettingBy For This Useful Post:
Rio (05-05-2015)
Old 05-15-2015, 04:19 PM   #13
GaryEvans's Avatar
Rewards Points: 84
It probably is possible to build a basement that is actually waterproof.
How much money you got ?
You basically have to build it like an undeground concrete water reservoir.
removing concrete, lots of new concrete, zypex, waterstop, engineers..........and more money of course.
GaryEvans is offline
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 07:17 PM
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Water table, cap on it, FC claps beginning above. Detail and flash? UpNorth Windows, Siding and Doors 5 09-13-2010 08:34 PM
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
