ADS Tile For Driveway Bridge - Excavation & Site Work - Contractor Talk
Old 06-21-2011, 11:09 AM   #1
mcdanie1's Avatar
Trade: Handyman
Greetings all!
I'm putting in a driveway that crosses a creek.The creek is only 24" wide where it went under the old bridge which was constructed of railroad ties. The ties were sinking into the creek so I removed those and replaced with a section of black corrugated ADS tile then backfilled with gravel and dirt to create a new bridge/ creek crossing.
The problem is that the end of the tile on the upstream side is about 1-2" above the water, and the water seems to be making its way to the other side of the driveway without going throught the tile. Water always finds a way, doesn't it?
So the delimma is how to correctly fix the problem and get water flowing through the tile so as to avoid the water erroding around the tile. One option would be to dig up the tile and dig the creekbed to be dug out so that the opening of the tile is just below water level on the upstream side. Another option would be rasing the water level so that water is flowing into the tile. This could be accomplished by adding rock to the creekbed to raise the water level. My concern with the latter is that the water will eventually find its way back under/around the tile.
Any thoughts would be greatly appreciated!
Thanks,
Mac
mcdanie1 is offline
Old 06-21-2011, 07:59 PM   #2
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
Re: ADS Tile For Driveway Bridge
Couldn't you install a flared end with rip rap or similar stone & fabric below it. That should stop water from getting under it allowing it to build up to flow line.
Upchuck is offline
Old 06-21-2011, 08:08 PM   #3
tgeb's Avatar
Rewards Points: 432
Head wall?
www.gebcon.com
tgeb is offline
Old 06-21-2011, 08:54 PM   #4
Precision 10
Precision10's Avatar
Trade: Excavation, site work, demolition and, trenching
Rewards Points: 81
you need to lower the bottom of your pipe approx 2'' below the bottom of the creek bed. Backfill with compacted gravel then put geo fabric at each end of pipe and place rip-rap on top of geo fabric. If you can, fill in between rip-rap stones with topsoil and plant grass. I would make sure that a 24'' pipe is going to be big enough to handle extreme rain.
Precision10 is offline
Old 06-26-2011, 09:26 PM   #5
mcdanie1's Avatar
Trade: Handyman
Thanks for the replies evryone!
mcdanie1 is offline
Time for a new tile guy? orson Tiling 22 06-14-2013 04:39 PM
Tile Installation Failures in a High End Remodel ChrWright Tiling 139 03-04-2013 06:28 PM
New tile and remodel guy to CT tile9 New Member Introductions 8 10-02-2010 02:06 PM
Tile job goin sour, what to do ? mendelectric Tiling 64 08-19-2009 02:49 PM
Looking for porcelain tile that mimics slate hillblazer Flooring 8 02-28-2009 01:13 PM
