2003 Volvo EC 160 B Troubles - Excavation & Site Work - Contractor Talk
Old 06-10-2019, 07:28 PM   #1
Scott Ducharme's Avatar
Trade: Excavation
Rewards Points: 2
Has anyone experienced loss of throttle while the machine is running?
And then comes out of it on its own.
Scott Ducharme is offline
Old 06-10-2019, 08:27 PM   #2
tgeb's Avatar
Rewards Points: 1,080
Re: 2003 Volvo EC 160 B Troubles
I'd start with checking the fuel filters, check pump pressure if you can.
Next would be seeing if there is something in the tank that might move around and block the pick up tube.
Sent from my SM-G930P using Tapatalk
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Fouthgeneration (06-10-2019)
Old 06-10-2019, 08:52 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,775
air leak into fuel suction line? Loose bleeder screw/nut/bolt.
Worn lift pump?
plugged fuel cap vent.... fill tank to see if it goes away.
flash light, fiber optics camera to check fuel pick-up bobbin and mesh screen.
Murphy switches activating?
low oil, hot water, etc....
ECU unit dead/dying replace with unit with correct software loaded for you model & serial #
Fouthgeneration is offline
Old 06-11-2019, 04:47 AM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,442
Friend says its typical Volvo of that era. Check the connections between the ECU modules and harness.
All I got.
SmallTownGuy is online now
Old 06-11-2019, 07:57 AM   #5
rustyjames's Avatar
Rewards Points: 1,732
Check grounds as well.
rustyjames is online now
