Cleaning Up This Brick - Pressure Washing ? - Pressure Washing - Contractor Talk
Old 02-11-2013, 08:33 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,476
What's a good way / chem - solution to clean up this brick ?
I only know / use Simple Green and bleach on siding and works great.
I get in there and brush everything but with what ?
I saw some Krud Cutter brand for masonry this evening. $12 gal - which usually doesn't go to far.
Cleaning Up this Brick - Pressure Washing ?-img_0027-001.jpg   Cleaning Up this Brick - Pressure Washing ?-img_0028-001.jpg   Cleaning Up this Brick - Pressure Washing ?-img_0029-001.jpg
We Fix Houses is offline
Old 02-11-2013, 09:23 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Cleaning Up This Brick - Pressure Washing ?
Just hit it with a pressure washer - kill the rest w/ bleach solution if you must.
Got some spalling going there - gonna take care of that too?
supersealconstruction.com
superseal is offline
Old 02-11-2013, 09:28 PM   #3
Thanks....
Brick - I'm way to slow on that. Brick guy for that.
Old 02-13-2013, 12:20 AM   #4
Gov contractor's Avatar
Trade: Masonry restoration
Rewards Points: 25
I would use D/2 to remove the mold, its a biological cleaner and protects for up to a year. Its expensive at $40 per gal but works well. The carbon staining can be removed with a good restoration cleaner, Hydroclean HT-626 is a great product
Gov contractor is offline
Old 05-04-2013, 08:22 PM   #5
ArtisanRemod's Avatar
Rewards Points: 582
any after pics?
ArtisanRemod is offline
Old 05-21-2013, 11:31 PM   #6
Joyfulfather's Avatar
Trade: Pressure Washing Painting Window Washing and Deck Repairs
I have found a bio barrier helps at least keeping the funk from coming back for some time. I have found obliviously bleach kills the green mildew but removing that dirt build up can be tough. Hot water helps. but just hitting it and taking your time with this work is the best solution. I have been tempted on a couple of brick jobs to bust out the sledge hammer though. I have a lot of 100 to 150 year old brick homes and buildings in my area and I know for a fact bleach doesn't do too much with it. A good acid based cleaner. any good pressure wash supplier in your area will have some great detergents for brick. I order most of mine out of Atlanta area they seem to be the best in my area. Let us know how it comes out.
Joyfulfather is offline
Old 05-21-2013, 11:36 PM   #7
Oh and please stay away from krud kutter. It is junk no matter what strength you use. Add some spic and span and save some money. It actually works better than krud kutter. I was in a jam and went this rout after spending 30 bucks on that junk. I now use Power House wash. It has changed my results tremendously.
Old 05-27-2013, 01:07 PM   #8
ProGrade's Avatar
Trade: Fence contractor
yes, definitely first try a commercial grade pressure washer, and afterwards use a bleach solution... if still needed, can always get some industrial strength mold remover product.
professional grade fence
ProGrade is offline
Old 02-03-2014, 03:42 PM   #9
Jeremy P's Avatar
apply some bleach and a surfactant, let dwell for 10 minutes, then hit with pressure washer.
We pressure wash a lot of brick patios here in Baton Rouge
Tiger Pressure Wash
Baton Rouge, LA
(225) 284-4527
Pressure Washing Baton Rouge
Jeremy P is offline
Old 02-03-2014, 04:03 PM   #10
Have Trowel, Do travel
brunothedog's Avatar
Trade: Artisan
Rewards Points: 1,188
nobody cleans with muratic acid anymore?
I used to love the days when you could look at an unattended bag on a train or bus and think to yourself...'Iím going to take that.'
brunothedog is offline
Old 02-03-2014, 10:14 PM   #11
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
We renovated a school quite a few years back and it had architectural panels over and under all the windows. It also had about 30000ft sq of brick to clean. We started off with 2000 psi washers and ended up using 5000 psi. The panels were slimy green when we started and beautiful white like new when we were done. The brick turned out great as well but you had to be very careful. Any mortar joints that were weak were soon found with the pressure washer.
muskoka guy is offline
Pressure washing and window seals. SuperiorHIP General Discussion 9 08-05-2012 07:19 PM
SW Florida Pressure Washing Chuck Bergman Charlotte and Sarasota County-Roof Cleaning 5282jt Pressure Washing 0 05-05-2011 08:35 AM
How to Safely Pressure Wash Your Home. PressureWashE Pressure Washing 1 07-02-2010 05:50 AM
Pressure Cleaning & Roof Cleaning in SW, Florida A1CC&PW Pressure Washing 5 03-08-2009 02:28 AM
Pressure Washing in Louisville, KY Marketing EPPSLLC Pressure Washing 2 03-07-2009 04:26 AM
