Chemical/detergent Attachment... - Pressure Washing - Contractor Talk
Old 07-18-2016, 12:20 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,844
Maybe a dumb question.
I have a fairly decent pressure washer with a CAT pump. I've only used the attachment that applies chemicals a few times years ago. I'm assuming the chemicals do not go through the pump.
Recently, I found some bag worms on 27 Leyland Cypress trees I have. I used a portable pump sprayer to apply the chemical but am not able to get the total coverage I want as the trees are 20' high.
I thought I'd use the pressure washer and an extension wand I have.
My question...finally...
Does the chemical attachment dilute the chemical...mix it with water, or does it come out as it is in the container?
I have to dilute the chemical with water before application and didn't want it diluted any further.
Thanks.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 07-18-2016, 02:28 PM   #2
Mordekyle's Avatar
Rewards Points: 6,086
Re: Chemical/detergent Attachment...
I think it dilutes it because the water in the pressure washer pulls the chemical into and through the hose and wand.
You should not need an extension wand. A two-story soap tip should do fine.
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Robie (07-18-2016)
Old 07-18-2016, 03:33 PM   #3
Robie's Avatar
What's a soap tip? I have the black tip...is that it?
Robie is online now
Old 07-18-2016, 06:24 PM   #4
Railman's Avatar
Trade: Railing
Rewards Points: 1,185
You might try one of these:
https://www.zoro.com/buckeye-unfille...00/i/G9783277/
You can usually find them on Craigslist for about $25 or so. We used to carry them around when racing MX to help clean up between motos. They were also a great on the hiway, (or stop light) squirt gun!
They can do 100psi, & 50 ft.
Railman is online now
The Following User Says Thank You to Railman For This Useful Post:
Robie (07-18-2016)
Old 10-21-2016, 03:59 AM   #5
Dave Mac's Avatar
Trade: Painting Contractor
Rewards Points: 688
yes it dilutes its have you thought about a 12 volt pump that would shoot it with out dilutions
www.davemacspowerwashing.com
Dave Mac is offline
Old 12-06-2016, 08:29 AM   #6
Driveway Cleaner
RalphQ's Avatar
Trade: Pressure Washing/Gutter Cleaning
Rewards Points: 214
depending on the size of your pressure washer, and the dilution rates the pesticide requires, you may be able to just use your washer to apply. Smaller pressure washers put out a stronger mix.
RalphQ is offline
Old 12-06-2016, 09:05 AM   #7
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Be mindful of drift when applying at those heights, particularly people, fish ponds, or other similar concerns downwind.
P42003 is offline
Old 12-06-2016, 09:30 AM   #8
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
Be mindful also of how the chemicals will react with any of the seals on the inside of your pressure washer. Those seals are all rubber, and I imagine pesticides wouldn't be an issue, but I think it would still be worthwhile to confirm it won't F**k up your seals.
CharlieDelta is offline
Old 12-07-2016, 10:35 PM   #9
Driveway Cleaner
RalphQ's Avatar
Rewards Points: 214
When you use a chemical injector(chem hose on pressure washer) chemicals don't go through the pump. It is siphoned into the stream after the pump through the venturi effect. The seals never see the pesticides.
RalphQ is offline
The Following User Says Thank You to RalphQ For This Useful Post:
CharlieDelta (12-08-2016)
48" Snow blower attachment for skid steer tgeb Contractor Swap 8 03-04-2015 06:30 AM
Telehandler Attachment FramerKMC Framing 0 11-08-2012 10:07 AM
Ledger board attachment livingsoulsdie Decks & Fencing 20 06-06-2012 09:42 AM
ProHauler 6x12 Steel Equip Trailer w/ Attachment Holders & Ramp Gat arbor pro Contractor Swap 0 08-09-2011 09:41 AM
muro attachment for perfect screw placement dvatt Decks & Fencing 0 12-23-2010 08:37 AM
