Wine Cellars - HVAC - Contractor Talk
Wine Cellars
Old 02-25-2009, 09:39 AM   #1
circajay's Avatar
Lightbulb
Wine Cellars
i am new and certain that this has been covered. But if we may review please. Split system chiller- in Connecticut- hate to put the condensor outside, cold starts kill em even with the heater, hate to put it inside the attic but with ducting to the condensor and the condensor outlet ducted to the outside it may work ? for a long time even. Cellarmate or breezaire ?
circajay is offline
Old 02-25-2009, 06:28 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,331
Re: Wine Cellars
Hey Jay, glad to see you made it to the site. Hopefully someone will have an answer for you.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 03-03-2009, 07:59 PM   #3
Professional Remodeler
rockingjwolf's Avatar
Trade: Professional Remodeler
Re: Wine Cellars
Hello from NJ. I learned the hard way. I used a Breezaire split system in a wine cellar we abuilt a year ago. Last year it worked ok, I think winter was a little milder but this year when it got down to 20 degrees or less, the unit would not work well. Breezaire was less than helpful and said install a crankcase heater like it was common knowledge. Nothing in their install specs or lit. refered to this. A heater from Grainger was installed it was marginally better. Hindsite, I would install the cond. unit in the basement, up on blocks, let it blow a little warm air around and that would be that. Again, don't depend on Breezaire, good equipt., crappy cust. serv.
rockingjwolf is offline
Old 03-03-2009, 08:06 PM   #4
BigMikeB's Avatar
Trade: HVAC
Rewards Points: 150
Re: Wine Cellars
I agree with the basement condenser install, we do it that way all the time. They really don't throw that much heat out. As for ducting condenser air, that will open up a whole can of worms that you don't want to play with. As for a crankcase heater, every compressor should have one with the exception of a domestic refrigerator.
The Veto toolbag, the Louis Viton of tool transport. The official toolbag of rich guys.
BigMikeB is offline
Old 03-05-2009, 01:28 PM   #5
NICKTECH
NickTech's Avatar
Rewards Points: 250
Re: Wine Cellars
a crankcase heater is just to keep the refrigerant from migrating to the oil on the of cycle. it sounds like the problem is low ambient temps are dropping the liquid saturated temp/pressure to low for the metering device to properly throttle refrig thru. this is common is these applications where there is a low abient situation. a remedy is to either heat up the area with some simple resistive heater or even 100w lights, but this consumes alot of power and require temp control wiring. the proper remedy for this is to install a reverse acting head pressure control that controls the condensor fan motor. the switch is n/o and closes when the head pressure rises high enough to allow the system to work right.
NickTech is offline
Old 03-08-2009, 08:40 PM   #6
BigMikeB's Avatar
Trade: HVAC
Rewards Points: 150
Re: Wine Cellars
So in plain english what your trying to say is install a fan cycling control.
If your lost baffle them with bull****.
BigMikeB is offline
Old 03-09-2009, 11:39 AM   #7
NICKTECH
NickTech's Avatar
Rewards Points: 250
Re: Wine Cellars
bingo!!
NickTech is offline
Red Wine & Marble Dash808 Flooring 15 01-26-2009 02:25 PM
Help-Split Wine Cooler in cold climates rockingjwolf HVAC 1 01-12-2009 10:18 PM
building a wine cellar vaultf600 Carpentry 8 02-22-2008 08:31 AM
wine celler bigjohnsons34 HVAC 6 02-06-2008 10:56 PM
Getting specialty wine stores to market my custom wine cellars? Mike Finley Marketing & Sales 4 05-09-2004 10:29 AM
