Whose Right? Hvac Quotes - HVAC - Contractor Talk
Old 02-07-2015, 07:33 PM   #1
Antropovsky's Avatar
Trade: Masonry
Rewards Points: 274
Hi guys, I'm getting quotes on adding a heat vent in my house and I've received two quotes. One of the guys says add a 5" pipe on the end of the square box (trunk?), while the next guy said from the top of the box (trunk?), this way will require se 90's. He said not to add to the end because it will cause static electricity and change the flow.
Sorry hvac isn't my lingo, tried to make this sound as sensible as possible.
Also, my pipes are 6", one said replace them with 5", the other said leave the 6's ... It will add comfort.
Antropovsky is offline
Old 02-07-2015, 08:29 PM   #2
klintala's Avatar
Trade: General Contracting/Concrete
Rewards Points: 136
Re: Whose Right? Hvac Quotes
We just finished an addition where the new was run straight off the end.
How far of a run are we talking?
Also, I don't see a reason for needing to switch your existing.
It would be interesting to hear from someone with more knowledge what benefits a 90 and downsizing might have.
klintala is offline
Old 02-07-2015, 08:48 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
I usually get enough bids for them to cluster around some price. I throw out the high & low bids and think over the others.
All bidders may come up with different explanations for what you should have, and all explanations sound credible. And maybe they are, depending on the unspoken assumptions each one makes.
GettingBy is offline
Old 02-07-2015, 09:20 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,233
Not my thing, but maybe this will help. BTW, are you sure they mentioned static electricity, or was it static pressure?
http://www.energyvanguard.com/blog-b...ay-Be-to-Blame
MarkJames is online now
Old 02-07-2015, 10:53 PM   #5
Trade: Masonry
Rewards Points: 274
Very possible it was static pressure, thanks for the links.
Old 02-07-2015, 10:55 PM   #6
Trade: Masonry
Rewards Points: 274
I'll measure as soon as possible.
Old 02-07-2015, 11:12 PM   #7
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
I would go off the top of the trunk as opposed at the end. Static pressure thing. Bitchin air off that run is likely, but, it might effect the flow to the rest of the system.
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
Dr Heat (03-01-2015)
Old 02-07-2015, 11:14 PM   #8
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,258
the reason the trunk duct is capped is so it builds static pressure (bursting pressure). Taking a heat run off the end of the trunk reduces the static pressure in the duct and therefore affects the other heat runs on the line. It is poor trade practice to install a takeoff on the end of a duct.
As far as changing the existing runs, they should be sized to deliver the correct cfm to the rooms they serve, regardless of their size. This might mean a 6" per room, 2 - 5" per room, etc. In residential, this commonly ends up being 5" runs, and lots of installers only put in 5", and some obviously think it has to be 5".
a round duct 90 elbow produces as much resistance as 5' of straight pipe.
Anthill is offline
Old 02-08-2015, 06:58 AM   #9
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,202
A start collar of take of on the end cap will cause lots of turbulence, can actually cause less air flow in the supply. Better to take off of the top of the duct. The fewer ells the better, as it is less restrictive to air flow.
A 5" round doesn't flow much air, so a 6" will be better. Its easier to damper down a 6" to decrease air flow, then to get a 5" to flow more air. Smaller supply runs don't increase the comfort in a house.
He was worried about static pressure.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-08-2015, 01:08 PM   #10
Trade: Masonry
Rewards Points: 274
The takeoff from the plethum is approx 10' 6", the distance from the end cap to the room I want to heat is approx 15', and will require 2 90's.
Old 02-08-2015, 01:32 PM   #11
beenthere's Avatar
Trade: HVAC
Can a side takeoff be used to eliminate 1 of the 90s.
Old 02-08-2015, 05:42 PM   #12
GettingBy's Avatar
So he should ground the pipes or use those things that are at the trailing edge of airplane wings?
Old 02-08-2015, 09:09 PM   #13
slowsol's Avatar
Rewards Points: 2,248
Lol. That's an interesting strategy. Just get a bunch of bids and the guys in the middle probably have it right.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
Old 02-08-2015, 09:29 PM   #14
GettingBy's Avatar
And if two or more middle prices are the same it may be price fixing. And if a guy says he'll match a lower bid it is a close cousin to price fixing.
All bidders in your area are using the same labor pool and available materials. Way low or way high outliers are suspect.
http://en.wikipedia.org/wiki/Outlier
I had a dent in my car. The mean (average) price was ~$200 and one guy quoted me $600 while intently watching my face, but I deadpanned it.
He didn't get the job.
Old 02-08-2015, 09:44 PM   #15
klintala's Avatar
Rewards Points: 136
That's about what I was picturing.
My (inexperienced in hvac) opinion is that you're not going to want the additional resistance of a 90 coming off the end cap if you're run is going to be 15ft + 90s. ...Unless all of your other runs are of similar distances.
klintala is offline
Old 02-09-2015, 09:35 AM   #16
Trade: Masonry
Rewards Points: 274
So if it comes off the side or top a few feet from the end cap, and still includes 90's.... that is going to be more effective (Just curiosity, since It's the alternative method)? The quote that came off the side needed a couple 90's, while the one of the end, eliminated at least one.
Maybe i'll try to diagram it.
Old 03-01-2015, 09:50 AM   #17
Dr Heat
Dr Heat's Avatar
Trade: hvac
Rewards Points: 306
Coming off the end cap is a code violation.
The reason it is a violation is because according to "SMACNA" and "ASHRAE" it changes the design protocol from an "extended plenum" or velocity pressure system to an octopus or straight velocity.
In an extended plenum all branches can be balanced; because the pressure builds in the duct and is equal (if installed correctly) at all branches. In a straight velocity system each branch is depending on its location of origin for it balance.
The reality is when you put a run out of the endcap in an extended plenum you change the characteristics of the whole system, making it very difficult to balance.
"All of these jobs would work nicely and probably give satisfaction if the men who knew the most or paid the most attention to detail had the lowest bid." Edward Richmond Pierce October, 1911
Dr Heat is offline
The Following User Says Thank You to Dr Heat For This Useful Post:
Antropovsky (03-02-2015)
Big Question Related to HVAC Trade - License hdung91 HVAC 3 05-29-2013 08:29 PM
Class A HVAC license ssch Help Wanted or Looking For Work 2 09-25-2012 09:58 AM
Legionnaires' Disease - HVAC Insurance Astrix HVAC 0 09-19-2012 09:24 PM
Florida, hvac /cac license ecoproair Help Wanted or Looking For Work 1 09-06-2012 11:50 PM
