What's The Function Of The Buffer On These Boots? - HVAC - Contractor Talk
Old 08-13-2019, 11:45 AM   #1
speller's Avatar
Trade: General
Rewards Points: 8
Hi guys general contractor replacing some of this ductwork on an old house, ductwork dates back to the old gravity furnace wanting to know why the ductwork overruns the boot, like a small buffer area just past each vent. Plan to just replace with standard sizes but trying to figure out why it was done that way to begin with.
Picture attached, but if you can't view the boots are large and square, and the square ductwork extends about a foot past the boot and terminates.
speller is offline
Old 08-13-2019, 12:00 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 778
Re: What's The Function Of The Buffer On These Boots?
If you are referring to a cloth or rubberized type of material it is to reduce vibration and allow the duct to flex.
griz is offline
Old 08-13-2019, 12:11 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,093
I'm guess the box extends so the hole for the boot can be cut later. Just another way to do it.
MarkJames is offline
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
hdavis (08-13-2019), speller (08-13-2019)
Old 08-13-2019, 12:11 PM   #4
speller's Avatar
Trade: General
Rewards Points: 8
Griz, the whole thing's (rusted) sheet metal. I was wondering why the ductwork sticks out past the register. It's got to be intentional because they're all like that in the house. I think it must be something to do with the way the air would move in the old gravity furnace system but I can't for the life of me figure out what or why.
speller is offline
Old 08-13-2019, 01:47 PM   #5
hdavis's Avatar
Rewards Points: 2,604
It has nothing to do with airflow, it's just fabrication/installation sequence.
hdavis is online now
Old 08-13-2019, 07:08 PM   #6
rrk's Avatar
Rewards Points: 3,518
I was once told it was for dust, the dust will collect there instead of blowing into the room. Not sure if true or not but gravity air systems were very dusty.
rrk is offline
The Following 2 Users Say Thank You to rrk For This Useful Post:
hdavis (08-13-2019), speller (08-14-2019)
Old 08-14-2019, 09:38 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
They aren't because they don't blow air.
Inner10 is offline
Fouthgeneration (08-16-2019)
Old 08-16-2019, 05:15 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,411
It would maximize the temperature of the air leaving the boot into the room, the colder air returning in the bottom half of duct.
No change in elevation no "chimney effect"....
And a tee would always flow more then the same sized 90 degree elbow,
plus I'd think it would be an "anti-reversion" device to reduce back flow when the bimetallic controlled damper closed the air feed to coal fire....
You wouldn't want the gravity furnace running backwards, hot up the floor return, cold returning through the ductworks...
Fouthgeneration is offline
Old 08-29-2019, 11:30 AM   #9
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
My guess is that it's a standard section of "rec-duct" and the installers didn't want to cut it down.
After all, it appears there's plenty of space for it, and who wants the left-overs on that?
http://www.37flash.com/
flashheatingand is offline
Old 08-29-2019, 08:27 PM   #10
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,220
Not suppose to tap off the very end of the duct. As it can cause turbulence.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
flashheatingand (08-30-2019)
