What Is Happening? - HVAC - Contractor Talk
What Is Happening?
Old 02-04-2011, 07:15 AM   #1
truelight's Avatar
Trade: electrical
What Is Happening?
It has been well below freezing here the last few days. last night stanfing by my return i could here the blower fan struggling to start so i switched from auto to fan on and it started blowing heat. It did well. This morning i noticed that the air coming up from my vents was less than warm. I put the stat on auto and the vents felt warm again but the fan was not pushing very fast. I put it on fan on and then the fan picked up speed again but it does not feel very warm.
Any wisdom?
truelight is offline
Old 02-04-2011, 08:56 AM   #2
hvacrman's Avatar
Trade: hvac and refrigeration
Rewards Points: 25
Re: What Is Happening?
most indoor fans are multi speed , sounds like your low speed windings are going out, or bearings and when you switch stat to fan on the medium or hi speed windings are able to compensate for bad bearings. of course it could be something else but sounds like this.
hvacrman is offline
Old 02-05-2011, 08:36 PM   #3
Dr Heat
Dr Heat's Avatar
Trade: hvac
Rewards Points: 306
sounds like its time to call the repair man
Dr Heat is offline
Old 02-05-2011, 09:18 PM   #4
The Flooring Guy
cork-guy's Avatar
Trade: Flooring
Rewards Points: 250
Can you just imagine that bill, especially if your in the snow storm hit areas? Makes you wish you were into HVAC and working 24 hours.
Cork Flooring - Educational information on cork flooring for consumers
Cork Flooring Twitter | Cork Flooring Facebook | Ventless Fireplace
cork-guy is offline
Old 02-06-2011, 09:00 AM   #5
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,516
We don't increase the rates just because it's real hot or cold. But, this is a good time of the year to be in hvac
flashheatingand is offline
Old 02-25-2011, 03:30 AM   #6
familyairman's Avatar
Trade: a/c heating and refrigeration do electrical small
Hi Im not exactly sure what kind of system you have but usually a heat cool system combination uses a higher fan speed to move cool air.When you set fan to on ,thats high speed fan and wikll not cycle or shut off in that selection.Usin high speed in heating mode will be running to much air and cool the heat down as its being deliveredto your home.With everything in auto the air doesnt move as fast because hot air or heat is easier to move than cold.hot air is lighter.If its noisy when your changing from auto to on could be bad news,the blower motor might be ready to go out.Its possible to have something else but unlikely!you need service call to give you a definite qualified answer.
familyairman is offline
whats happening everyone.... BrianFox New Member Introductions 2 05-13-2009 08:35 PM
Anyone heard of this happening? JamesNLA Plumbing 1 04-05-2008 09:23 PM
Anybody know whats happening in Arkansas? btymerenovate General Discussion 1 12-31-2007 12:05 PM
Copper Pipe, Pin Holes , is it happening by you?? tzzzz216 Plumbing 16 11-18-2006 08:48 PM
