In Wall Heater - HVAC - Contractor Talk
In Wall Heater
Old 08-17-2007, 12:33 AM   #1
What stop sign?
ODDBALLS's Avatar
Trade: Home Remodel, repair, and maintenance.
Rewards Points: 150
In Wall Heater
I have a customer with a converted garage. It is being used as a art studio for her son. He needs heat in the winter and cold in the summer. Does such a beast exist that is a in wall combo unit? If so, is it worth it? Or, is it better to do each separate? Are these units safe? I have already found some separate units on line. Just need to know which way/brand is better. They need to be able to run off of 110V. Thanks.
ODDBALLS is offline
Old 08-17-2007, 05:19 AM   #2
oldgoat's Avatar
Trade: painter
Rewards Points: 150
Re: In Wall Heater
Will all of it have to be electric or can you get gas or propane for the heat?
oldgoat is offline
Old 08-17-2007, 06:32 AM   #3
What stop sign?
ODDBALLS's Avatar
Rewards Points: 150
Re: In Wall Heater
If it can be electric, that would be easiest. Trying to keep cost down.
ODDBALLS is offline
Old 08-17-2007, 06:39 AM   #4
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,030
Re: In Wall Heater
I built an art studio three years ago. We used a p-tac unit to heat and cool. It was all electric & required no ducting (I think they're pretty much the same type of unit you find in hotel rooms).
Required 220v service and was quite an expensive little booger.. (around $2,500 if I remember right) But it did a great job of heating/cooling the space.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Instagram - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - Master of the Home Feature
ChrWright is offline
Old 08-17-2007, 06:51 AM   #5
What stop sign?
ODDBALLS's Avatar
Rewards Points: 150
Re: In Wall Heater
Yeah, I found those units. A little pricey for what she wants to do. The units that I had found were separate and about 3 bills each. She just needs something simple.
ODDBALLS is offline
Old 08-17-2007, 12:06 PM   #6
oldgoat's Avatar
Trade: painter
Rewards Points: 150
Re: In Wall Heater
They make through the wall and window type heat/AC units also. Some just use heat strips and others use a heat pump with a heat strip backup.
oldgoat is offline
Old 08-18-2007, 06:22 PM   #7
BigMikeB's Avatar
Trade: HVAC
Rewards Points: 150
Re: In Wall Heater
Install a window unit a/c @$150.00 and a oil filled heater @100.00 or do it right and get a P-tac. You can't make chicken soup from chicken poop.
BigMikeB is offline
Old 08-18-2007, 07:00 PM   #8
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Re: In Wall Heater
A word of caution....while the electric model seems least expensive, don't forget someone may have to run electricity to it - can your service handle the new load in addition to the existing load?
Electricity is expensive.
Check your fuel bill(assuming fossil fuel of some flavor).
Celtic is offline
Old 08-19-2007, 10:06 AM   #9
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
Re: In Wall Heater
How often do you need heat there? How cold does it get down too? When I think NM, I think a/c would be the priority.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 08-19-2007, 10:32 AM   #10
Fentoozler
Celtic's Avatar
Re: In Wall Heater
Good point....I didn't notice the OP was in NM..
Celtic is offline
Old 08-21-2007, 01:17 AM   #11
What stop sign?
ODDBALLS's Avatar
Rewards Points: 150
Re: In Wall Heater
Electricity is not a problem. I didn't ask how often they would use it. My fault. I will ask. Yes we do get a winter here. We had snow on the ground many times last year. That is a huge misconception about NM. 2 hours north of me, i'm in Albuquerque, there is 4-7' of snow. It is some of the best snowmobile freeriding in the country, and i've been all over WY, CO and UT sledding. I think she just would like something simple to take the chill off.
ODDBALLS is offline
Old 12-22-2015, 07:51 AM   #12
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,500
Re: In Wall Heater
They make a window unit that includes heat...maybe just frame in an opening for one of these:
mstrat is offline
Old 12-22-2015, 01:24 PM   #13
TimberlineMD's Avatar
Rewards Points: 738
Re: In Wall Heater
This thread is 8+ years old.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
The Following User Says Thank You to TimberlineMD For This Useful Post:
beenthere (12-23-2015)
Old 12-22-2015, 06:08 PM   #14
GettingBy's Avatar
Rewards Points: 6,486
Re: In Wall Heater
That means Heisenberg has already met his maker.
There are upfront lump sum costs and continuing costs. How long you live there may govern the economic choice.
GettingBy is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 06:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
moving centennial wall stacker Masonry 4 10-19-2006 11:12 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
Bathroom wall heater locofoco Electrical 7 12-21-2005 10:24 PM
