Vents And Registers - HVAC - Contractor Talk
Vents And Registers
Old 06-05-2015, 07:18 PM   #1
balavay's Avatar
Rewards Points: 12
Vents And Registers
Doing some woodwork for a customer - floor sections, stairs, window casings and trim, installing/replacing baseboards.
Not sure about something - customer asked about replacing very long baseboard vents with smaller modern ones (and adding baseboards), for a cleaner look. House was built in 1950s, ~2100 sq. ft. ranch style with a basement, central heat/air. All baseboard vents in the house are very long, probably original. For example, shown in the first two pictures, is a 15 foot long vent in the living room under the window. These are not baseboard heaters, there is just empty space behind it, except for two 14" openings which have a flap that can be closed/open by pulling on a chain. Looking at it in the basement, there are two 6" ducts coming from the main supply duct and are connected with 90 degree boots to those 14" openings in this baseboard vent. Does this vent need to be that long, is it for an even distribution of air? Would there be any issues if I replaced it with two small custom vents above the 14" boot openings? I guess I wanted to confirm if these are functional since I am no HVAC expert by any mean...
Same question regarding the baseboard intake vents that are in the hallway (shown in the third picture). Each one is 2.5 feet wide and the hallway is 20 feet long. Do they need to be this wide?
Thanks in advance for any advice or suggestion!
Vents and registers-floor-register-2_small.jpg   Vents and registers-floor-register-1_small.jpg   Vents and registers-floor-intake-vent-2_small.jpg
balavay is offline
Old 06-06-2015, 05:51 AM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,178
Re: Vents And Registers
The supplies don't need to be that long. You can probably use a 1.5, or 2 foot long baseboard supply instead.
http://www.hartandcooley.com/product...diffuser-45-ht
http://www.hartandcooley.com/product...board-diffuser
The returns are probably already smaller then they should be. So they need to at least stay as large as they are.
beenthere is offline
Old 06-06-2015, 09:01 AM   #3
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,512
We usually have the returns up high on the wall. Might want to to put two 4* ten registers on either ends of the windows. I don't think I recall seeing supply registers like that
http://www.37flash.com/
flashheatingand is offline
Old 06-07-2015, 02:01 PM   #4
balavay's Avatar
Rewards Points: 12
Thanks for the info! Does it have to be a "diffuser" or can it be a simple vent in the floor?
Why do you say that the returns are "probably smaller", aren't those designed for the house? Or did they design them on the smaller side in the 50s?
balavay is offline
Old 06-07-2015, 02:07 PM   #5
balavay's Avatar
Rewards Points: 12
"Returns up high on the wall" - are your referring to those two in the hallway? I am guessing that has to be done when the house is built, not retrofitted?
4 by 10 registers, just in the floor, like vents? I agree, I've never seen 15 foot baseboard supply registers like that, I tried searching online, but could not find anything close, must be a 50s thing? Btw, would those be called registers, vents or something else, maybe I am not searching for the correct thing...
Thanks again!
balavay is offline
Old 06-09-2015, 05:22 AM   #6
beenthere's Avatar
Trade: HVAC
You can convert the supplies to floor registers. But you have to cut the floor out away from the wall to get the new registers in. And of course repair the floor at the wall then.
Those return registers/grilles at 8x30 allow the air to pass through them quietly if you have enough of them. If you reduce them to 16x8 without adding more of them, the same amount of air now travels twice as fast. And the return grille is 4 times as restrictive to air flow.
Most homes have under sized duct systems to begin with. Adding more resistance by using smaller return grilles just hurts the system more.
The Following User Says Thank You to beenthere For This Useful Post:
flashheatingand (06-18-2015)
Installing built in vents into already installed 3/4" wood floor nhill2090 Flooring 12 06-05-2015 08:08 PM
