Lately I have been noticing on my home AC unit that the thermostat will click to call for AC and then about 3-4 minutes later the blower comes on and then 3-4 minutes later the condenser kicks on.
In all my 17 years in the house when the thermostat calls for cool, the fan comes on simultaneously as the condenser. I have never noticed this lag before. I suspect something is up.
Any idea what is wrong or is this normal for hot Florida days? I keep the house at 78 during the day until bed time when I really cool it off.
Resolved, hopefully. Not sure why I didn't try this to begin with. I killed power to it all and then turned it back on. Things are back to the normal sequence.
We must have had a power outage, power on/off quickly, a while back and cause the units to act like this.
This morning I decided to take my shop vac out and suck all the crap out of the drain line. Ever since doing this, the unit has been running like it should.
In the past when the line is clogged it just prevented the unit from coming on all together.
Is there a "Big Brother" energy demand reduction control that allows the utility to delay your cooling(power) load as part of an area wide scheme to delay construction of a needed central power plant.....
look for a phone line going to your disconnect switch....
possibility two, and anti-icing mode, that allows an iced up a-coil to thaw?
A clean air filter would reduce the "fertilizer" available for the stuff that plugs your drain....
Condensation drains need to be visible at some point to lower chances of damage from plumbing failures.....
Ask your doctor about Legionaries disease.... not good....
Glad you got it resolved. General maintenance on condensate drains is one of the most overlooked things there is in this biz. And one of the simplest things to do.
Related Threads
3.5M posts
151.3K members
Since 2003
