Steam Pressure - HVAC - Contractor Talk
Steam Pressure
Thread Tools
Old 12-09-2009, 06:26 AM
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Steam Pressure
Anyone know at what pressure a steam heating boiler should be set ?
chris n is offline
Old 12-09-2009, 10:15 AM
Tom M's Avatar
Rewards Points: 9,542
Re: Steam Pressure
Lower the pressure the better it works. 2-5 lbs is the norm.
Tom M is online now
Old 12-09-2009, 10:21 AM
Tom M's Avatar
Re: Steam Pressure
Check the air vents on the radiators if one is missing that could screw with you. They regulate the rate of heat through the system. If you change them becareful the vents may look alike but are rated differently by rad size, floor level and loop length. If you have too much pressure like 15 lbs the safety relief valve should discharge on the floor.
Tom M is online now
Old 12-09-2009, 07:13 PM
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,226
Re: Steam Pressure
No residential system is suppose to need more then 2PSIG.
If it does. Then something else is wrong with the system. Or the system was never designed or installed right.
beenthere is offline
Old 12-09-2009, 07:17 PM
chris n's Avatar
Rewards Points: 4
Re: Steam Pressure
Thanks, I thought it was 2 but wanted to check and make sure.
chris n is offline
Old 12-10-2009, 07:17 PM
NICKTECH
NickTech's Avatar
Rewards Points: 250
Re: Steam Pressure
the p-trol (pressure control) is set to cut out at about 3 psi. the average normal boiler operates on average with less than 1 psi. normal steam pressure will vary from boiler to boiler but unless you like burnin fuel or need the pressure to travel further, then you'll see 1/4 to bout 1/2 psi on the guage
NickTech is offline
Old 12-10-2009, 07:24 PM
beenthere's Avatar
Trade: HVAC
Re: Steam Pressure
Systems running at ˝PSIG and less. Are vapor systems.
Old 12-10-2009, 09:13 PM
BigMikeB's Avatar
Trade: HVAC
Rewards Points: 150
Re: Steam Pressure
As long as the vents are good and the pipes are insulated steam should travel just fine at 1psi.
The Veto toolbag, the Louis Viton of tool transport. The official toolbag of rich guys.
BigMikeB is offline
Thread Tools
Rate This Thread
Kitchen faucet losing pressure Kent Whitten Plumbing 19 11-26-2011 02:31 PM
problems with pressure ryanapplequist Plumbing 11 11-20-2009 12:29 PM
Steam bending crovello Carpentry 9 10-20-2009 06:49 PM
New Pressure Washer maverick28 Tools & Equipment 11 07-06-2009 09:38 PM
low pressure steam piping thom HVAC 5 08-09-2008 09:23 PM
