Space Heater - HVAC - Contractor Talk
Space Heater
Old 04-04-2019, 08:27 AM   #1
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Space Heater
I have a space heater that has stopped working correctly. I replace the mother board and it works the same. The fans come on but it doesn't fire up. I looked at the spark plug thing and it looks like new condition. Whats parts do I throw at it ?
It used to make a ticking sound as it was firing the gas but that noise has stopped.
HubbaBubba is offline
Old 04-04-2019, 08:28 AM   #2
MarkJames's Avatar
Rewards Points: 18,855
Re: Space Heater
Is it gas, and does it have a thermocouple?
MarkJames is online now
Old 04-04-2019, 08:43 AM   #3
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: Space Heater
It is gas, I will look at the schem for a thermocouple.
Old 04-04-2019, 12:54 PM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 404
Re: Space Heater
Ticking noise that isn't there any more might be a bad igniter??
mrcat is offline
Old 04-04-2019, 07:23 PM   #5
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Re: Space Heater
Pressure switch is probably not closing.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
flashheatingand (04-14-2019)
Old 04-05-2019, 03:30 PM   #6
sefiroxx's Avatar
Trade: remodel/handy
Rewards Points: 152
Re: Space Heater
Ticking is electronic spark. Bypass the safety loop to see if it starts ticking again (safety loop includes exhaust fan sensor, high heat sensors etc). If ticks then sensor is bad. If not then igniter or control board.
sefiroxx is offline
The Following User Says Thank You to sefiroxx For This Useful Post:
Fouthgeneration (04-05-2019)
Old 04-05-2019, 08:40 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,725
Re: Space Heater
Safety switch on door cover?
Reznor has wire diagrams with # off machine.
Fouthgeneration is online now
Old 04-05-2019, 09:01 PM   #8
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: Space Heater
no switch on door
Old 04-08-2019, 01:42 PM   #9
Bob Jones Heating
dashawn42000's Avatar
Trade: HVAC
Rewards Points: 2
Re: Space Heater
are there any blinking lights
dashawn42000 is offline
Old 04-09-2019, 05:58 PM   #10
Trade: Masonry
Re: Space Heater
Does the flex hose have a anti leak "valve" similar to 20 # L.P. tanks???
Reset or remove....
missed a ground strap or wire needed for High voltage initiator?
Check induced draft fan is actually blowing that right amount of air.--damaged/blocked squirrel cage fan?
Is there a reset pin hole on board? many gas furnaces will lock out after x number of false starts.....
dead bugs in gas valves? plugged "dope" screen on gas valve.
Replace /check 24 volt transformer and or hot wire t-stat to always on?
Again reznor web site will have a trouble shooting chart.....
Fix it now, before next heating season...
What does your Fire Marshall think about the O2 supply in the same room as open flame? See OP attachment......
Old 04-13-2019, 12:12 PM   #11
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: Space Heater
replaced pressure switch, still no go
Old 04-13-2019, 12:54 PM   #12
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: Space Heater
I pulled out the high temp limit control and one of the wires inside had become undone. It must have just rattled loose on its own. It fired up, thanks for the help-
Old 04-13-2019, 01:12 PM   #13
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,241
Re: Space Heater
Nice simple (hidden) fix.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 04-13-2019, 08:15 PM   #14
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: Space Heater
more like stupid fix
Old 04-13-2019, 11:44 PM   #15
Trade: Masonry
Re: Space Heater
What is the O2 pipe for?
Black Iron Gas Pipe (Hot Water Heater) 2paulm Plumbing 3 04-14-2017 08:00 PM
Question Regarding Heater Mozart Electrical 14 10-25-2016 09:53 AM
Exterior plug placement jimrun Electrical 8 05-31-2012 08:53 AM
Water heater - on demand or tanked? G.C. Plumbing 2 09-06-2010 06:49 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
