So Cal, The WRONG Way Or The RIGHT WAY - HVAC - Contractor Talk
Old 04-21-2017, 08:37 AM   #1
HVACProJoe's Avatar
Trade: HVAC Lead Installer
Rewards Points: 8
I'm a HVAC installer and I work in the Southern California area. No one in California properly installs ductwork as in they run over 30 feet of flex duct from a square plenum directly off the furnace to the boot.
The correct way to install ductwork is have a trunk line in either the extended plenum or extended plenum reducing method and have your branch ducts with no more than 6 feet of flex going to your boots.
I am tired of every single company doing it the wrong way
Companies want to be all high tech but when they do not compensate static pressure with their 30 feet of flex duct runs with a unit and cannot properly install ductwork
I think they first need to install HVAC equipment properly before they start getting all high tech
My question is I just started at a new company and I am a master sheet metal fabricator and instead of metal ductwork I want to use duct board to fabricate trunk lines
Do I show my employer how to properly install ductwork or do I continue to do the ridiculous 30 foot flex duct runs
I am 26 years old and have five years in the trade, I am a lead installer commercial and residential .My employer allows me to design and install all systems to my liking as in he lets me do my job and stays out of my way.
However I have not yet done a trunk duct run because I am not sure how to go about it
Do I just do it and explain to him why or what do I do guys help me out.
Sent from my SM-J320V using Tapatalk
HVACProJoe is offline
Old 04-21-2017, 09:16 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,992
Re: So Cal, The WRONG Way Or The RIGHT WAY
what's the man hours & material cost difference?
If your boss has to competitively bid work it may not be in the cards.
The other issue that may come up, at least on commercial, is that your method may deviate from the plan.
griz is offline
Old 04-21-2017, 09:44 AM   #3
HVACProJoe's Avatar
Rewards Points: 8
It's MUCH cheaper and faster to do any of the trunk line methods rather than flex. Commercial is done properly, with metal spiral or square duct. This issue is with residential. And my method being any of the trunk line methods work in every given scenario, if you didn't know how to build transitions or elbows etc then you would have a tough time. However my question is how do I go about it because the way they do it is completely wrong
Sent from my SM-T713 using Tapatalk
Old 04-21-2017, 09:56 AM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 1,744
Remember that any way that the ducts are run the system must have no more than 5% leakage per the 2016 energy code.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Calidecks (04-21-2017)
Old 04-21-2017, 10:13 AM   #5
HVACProJoe's Avatar
Rewards Points: 8
Ya there is no leakage in either method, however the flex duct ran straight from a box plenum off a Air Handler has up to 4x velocity and air flow loss and a insane amount of restrictions if the flex is ran over 6ft compared to other way more efficient methods
Old 04-21-2017, 10:15 AM   #6
HVACProJoe's Avatar
Rewards Points: 8
My question still remains, how do I go about doing it the correct way? Just do it and show the results and data after? Or show him why first? Like I said I am a lead Installer and every Job I design and install myself, but on duct only jobs I have not done the trunk method yet due to the fact of why I need help with my question
Old 04-21-2017, 04:59 PM   #7
Designer/Contractor
Rio's Avatar
Talk to your employer about it and see what they say..............
Rio is online now
flashheatingand (04-21-2017)
Old 04-21-2017, 05:04 PM   #8
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,544
I'm not a HVAC guy, but I am a boss. If you came to me and showed me a method that was better AND cheaper I would be ecstatic.
Talk to your boss, what's the worst that could happen?
B.Johnson is offline
Old 04-21-2017, 05:58 PM   #9
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 156
I'm not in the HVAC trade, but I see this often in crawlspaces and think to myself, are people really this [email protected] incompetent or they just don't give a [email protected] Really ticks me off to see.
P42003 is offline
Old 04-21-2017, 06:28 PM   #10
hdavis's Avatar
Rewards Points: 2,058
Definitely show your boss it's faster, cheaper, and gives better air flow, so better cooling / heating and less electricity use.
hdavis is offline
Old 04-21-2017, 07:42 PM   #11
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,516
It's not what you say, but how it's said.
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
Old 04-21-2017, 08:55 PM   #12
Designer/Contractor
Rio's Avatar
Can you meet the insulation requirements with it?
Rio is online now
Old 04-22-2017, 03:27 AM   #13
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,180
Rectangular trunk line is not cheaper than a flex duct system. Flex systems are done because they are cheaper.
Nothing wrong with flex duct systems, if they are sized and installed properly. But most use a duculator for sheet metal to size flex duct, which is an incorrect thing to do.
Talk to your boss. But if you haven't done a trunk line system yet. You may be in for a surprise when you talk to him.
PS: Don't confuse flexible duct connector regs with flex duct, they are not the same.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Rio (04-22-2017)
Old 04-22-2017, 11:22 AM   #14
Trade: H.v.a.c.
I suspect he just wants it done, in a manner that does not draw his attention. If your way cost significantly more, in materials or labor, it's likely going to be a problem. Especially if the boss hasn't heard complaints about the other method.
If your way is less expensive, and it works great, why would (s)he complain?
Old 04-22-2017, 05:14 PM   #15
Designer/Contractor
Rio's Avatar
Thinking on it it's hard to think of a more economical, not better, but economical way to run a duct than those giant slinky type pre insulated ducts the HVAC guys fill up the attics with.
Rio is online now
Old 04-24-2017, 08:08 AM   #16
Trade: H.v.a.c.
Flex duct is fine, just need to pull it tight, and strap it consistently. labor cost would get quite high if we were to run it in matal, mastic all joints, and then insulate. Especially in most crawlspaces.
OK which one of us put the garage in the wrong spot? Red Adobe General Discussion 14 07-14-2012 09:11 PM
Messed up/posted new thread in wrong category hestonreno Site Feedback and Suggestions 4 02-26-2012 10:45 AM
why is this wrong? summithomeinc Electrical 33 02-04-2012 09:11 AM
what is wrong with people master of none Decks & Fencing 51 09-09-2011 07:00 PM
