Recharge Refrigerant (R134) - Page 2 - HVAC - Contractor Talk
Old 08-20-2017, 05:44 PM   #21
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,516
Re: Recharge Refrigerant (R134)
Originally Posted by randyle2015 View Post
That's very interesting...if the weight is off that system is required then it won't cool even though it's not over charge? I don't have a right equipment to weight it. I was thinking the other components could be failed hence the system won't cooling...
Harbor Freight has a postage scale that works pretty good. About thirty dollars. They have less expensive models, for the small cans like at the auto parts stores.
http://www.37flash.com/
flashheatingand is offline
Old 08-20-2017, 07:20 PM   #22
randyle2015's Avatar
Rewards Points: 24
I noticed the low side indicted the same psi -20 ( was 3 psi) whether the refrigerator power on or not. I'm hoping the compressor still working as I just replaced it with a brand new one. Not sure why the low side gauge doesn't Change....I did vacuum for half an hour last night.
randyle2015 is offline
Old 08-20-2017, 10:11 PM   #23
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
The issue with my truck was that when I charged to correct pressure the head pressure would run too high. I figured there was a blockage so I flushed the system and replaced the orifice tube and the results were the same. The weighted charge gives a bit of a low suction side but the head pressure stays in check.
I used my wife's food scale to weigh it in. The drum I had only had around 13 pounds in it and the food scale had a max capacity of 15lbs so it worked out.
SuperiorHIP is offline
What refrigerant in your home's system? Electric_Light HVAC 7 07-10-2012 10:36 PM
Refrigerant gases are the new narcotics? Electric_Light HVAC 7 08-30-2010 07:51 PM
HAHA air conditioner thieves getting Federal charges for refrigerant "Freon" venting Electric_Light General Discussion 1 08-19-2010 08:16 AM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
