-   HVAC (https://www.contractortalk.com/f6/)
-   -   Recharge refrigerant (R134) (https://www.contractortalk.com/f6/recharge-refrigerant-r134-355569/)
randyle2015 08-13-2017 07:17 PM
Can we use Artic Freeze synthetic R134a+ that sell at Harbor Freight to recharge on the refrigerator (Kenmore)?
The refrigerator label indicated that R134 with 4.96oz to be used so I assume that we can recharge any R134 refrigerant either with a regular or synthetic.
Someone at the store said that the Artic Freeze R134A+ is used for Auto but I can be used for refrigerator too as long as it doesn't over charge.
I'd like to get more inputs from experts.
Thanks,
Randy
griz 08-13-2017 07:22 PM
do you have a tap on the refer to even add refrigerant?
when refrigerant runs low there is likely something way wrong somewhere in the system.....
randyle2015 08-13-2017 08:12 PM
I have a bullet piercing value to tap on the processing tube. I tried to change a relay and overload relay protector but it didn't help. The compressor seems running fine as well as condenser fan. I just need to check the freon level by using the gauge. Just need to confirm whether the synthetic R134A+ can be recharged for the refrigerator. Any thoughts?
randyle2015 08-13-2017 08:15 PM
https://uploads.tapatalk-cdn.com/201...b3d275d1a1.jpg
flashheatingand 08-14-2017 09:21 AM
should be alright.you have gauges to check the charge? Anywhere on the nameplate that indicates how much the factory charge was?
randyle2015 08-14-2017 01:04 PM
The label inside the refrigerator indicated 4.96Oz for R134A
randyle2015 08-14-2017 01:09 PM
Have anyone done this before by using the synthetic R134A+ for Auto on the refrigerator? Does it really work? What's the difference between the R134A for Auto and R134A for refrigerator????
SuperiorHIP 08-14-2017 11:23 PM
R134a is R134a, just be sure it doesn't contain oil or any other additives (maybe it doesn't matter but in such a small system I wouldn't want to add anything other than refrigerant).
hdavis 08-15-2017 08:14 AM
134a is 134a.
Auto recharge cans frequently have leak stop, PAG oil, UV dyes,...
flashheatingand 08-15-2017 09:33 AM
What have you got to lose? If they system is low on refrigerant, it doesn't do you much good, otherwise. Unless you want to put a block of ice on the top cabinet, every few days. :jester:
randyle2015 08-15-2017 10:17 AM
Originally Posted by hdavis (Post 6195281)
134a is 134a.
That's true. Other said that it's better to use pure R134A which normally come in a big tank (clean without oil) instead of using the refrigerant 12 oz can for auto where they put 1 or 2oz of oil.
hdavis 08-15-2017 10:59 AM
I've bought plenty of small cans that had nothing but refrigerant.
randyle2015 08-15-2017 03:24 PM
That's true. Other said that it's better to use pure R134A which normally come in a big tank (clean without oil) instead of using the refrigerant 12 oz cans for auto where they put 1 or 2oz of oil.
sailsfast 08-17-2017 12:02 AM
You should evacuate the system and weight back in the correct charge. Only way to get it right with such a small charge! You won't get it right using your gauges. The question is were it went.
Sent from my SM-N915T using Tapatalk
randyle2015 08-20-2017 09:39 AM
I replaced the compressor, vacuum all the air out and then recharged refrigerant (R134a) slowly. After reading the low side gauge, it shows 3psi which is expected. I have waited for 10 hours and the refrigerator still not cooling. I did even replaced relay, overload protector relay and filter dryer and still not cooling. Any suggestions? Check Defrost timer?
flashheatingand 08-20-2017 10:31 AM
Possibly a restriction at the metering device.
hdavis 08-20-2017 10:34 AM
Maybe this...
SuperiorHIP 08-20-2017 12:36 PM
I would absolutely weight in the charge. I'm no a/c pro (obviously), it took me 3 tries with my truck and finally called my a/c buddy and he said weight it in. The gauges looked good when I charged it but the system is designed for whatever that sticker says the weight should be. Weighted in the charge and while it seeed a little low on the suction side its been problem free since.
randyle2015 08-20-2017 04:37 PM
That's very interesting...if the weight is off that system is required then it won't cool even though it's not over charge? I don't have a right equipment to weight it. I was thinking the other components could be failed hence the system won't cooling...
TimberlineMD 08-20-2017 05:29 PM
Time for a new fridge..
