Re-attaching Battery Spring On Hunter Thermostat - HVAC - Contractor Talk
Old 08-19-2018, 10:00 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,848
After our thermostat kept showing "low batt" in shutdown mode I cleaned the contact surface that appears to be copper, and that had a greenish corrosive build. Sandpapered and then vinegar. That worked and I was able to reset.
It takes (3) 1.5 v batteries and the top one, when working around the tight confines, sprung loose its spring. Nothing seems to have snapped - but how do you get that somewhat folded-end back into the center hole of its tiny nipple ? Looks to be fabbed prior to assembly.
Should it be soldered?
Would post a pic, but I don't want to risk taking the thing apart again as it was compressed "loose" back in contact and I felt lucky just to be able to close it up and reprogram.
Will do on the next batt change in the coming months - nobody wanted lithium!
artinall is offline
Old 08-19-2018, 10:58 AM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: Re-attaching Battery Spring On Hunter Thermostat
"If" I am understanding you, the metal tab/spring is effectively riveted onto a stud. Solder should work.
FWIW I have a small handheld sandblaster I bought for doing a flood recovery on a very special Porsche. With bead blasting media it works awesome for cleaning up metal contacts.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
artinall (08-19-2018)
Old 08-19-2018, 11:35 AM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,659
I'd have to see it to recommend a method of reattachment.
But cautionary note for the future: Contacts like that are almost always electroplated. Sandpaper will shine them up, but they'll corrode again much more quickly with the plating removed.
Better to just burnish them with a piece of copper or brass. If you must use an abrasive, try a pencil eraser.
Tinstaafl is offline
Old 08-19-2018, 11:51 AM   #4
artinall's Avatar
It looks copper through and through... looks anyway
artinall is offline
Old 08-19-2018, 12:13 PM   #5
Peter_C's Avatar
Rewards Points: 412
True, and I didn't mention it but a grease would be in order, which is what I did for the flood recovery vehicles electrical system.
Peter_C is offline
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
artinall (08-19-2018), Tinstaafl (08-19-2018)
Old 08-19-2018, 01:20 PM   #6
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,518
Throwing it in the trash and buying a new one is out of the question?
smh
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
avenge (08-19-2018), Inner10 (08-19-2018)
Old 08-19-2018, 04:23 PM   #7
artinall's Avatar
smh
It's not my decision...or I would.
Has 15 yrs on it.
artinall is offline
Old 08-19-2018, 09:54 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,354
Has 15 yrs on it.
It probably doesn't need the battery.
Inner10 is offline
flashheatingand (08-21-2018)
Old 08-21-2018, 06:25 PM   #9
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,847
Replacement NEW E-star rated thermostat would most likely get a rebate on your power bill(s)
I.E. the NEW one would pay you to be installed.....
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
artinall (08-22-2018)
Hello From Palm Spring Craig Harrison New Member Introductions 1 10-17-2012 01:23 PM
The battery or the tool? CrpntrFrk Tools & Equipment 65 06-17-2012 12:49 PM
dewalt cordless circular saw battery dies fast christoff Tools & Equipment 20 07-27-2010 11:55 AM
Thermostat Recall Shock Hazard MechAcc HVAC 1 07-27-2009 01:58 AM
Thermostat Wiring Help GoodHouse HVAC 2 03-05-2009 05:47 PM
