Radiant Heat In-slab Help - HVAC - Contractor Talk
Old 09-05-2020, 04:59 PM   #1
sbmmm's Avatar
Trade: General
Rewards Points: 32
Hello,
A residentual unit has radiant heat installed in-slab that services two rooms. I want to consider the possibilities of converting the second room into a dedicated master bathroom. Currently one radiant heat zone services both rooms and the room I want to convert is at the end of the radiant pipe loop. My problems is that I am looking to construct drain lines for the new bathroom fixtures (shower, tub, sink, and toilet).
Is it possible to break into the slab near the door threshold, cut the radiant heat line in two places ("supply and return"), chip away the concrete to expose pipe lines, cap the the two pipe ends during construction, break up slab in desired bathroom, build out bathroom and reconnect radiant pipe lines to use in the newly poured slab of said bathroom?
Sounds problematic, but has anyone actually done something like this before? Other possible solutions? Thanks.
EDIT: The more I think about how PEX is coupled, it doesn't seem to be appropriate for in-slab use. Still hoping for a solution...
sbmmm is offline
Old 09-06-2020, 09:05 AM   #2
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 356
Re: Radiant Heat In-slab Help
It would require covering the new connections with concrete? It seems like a disaster waiting to happen.
rjconstructs is online now
Old 09-06-2020, 11:45 AM   #3
sbmmm's Avatar
Trade: General
Rewards Points: 32
Without having done this specific repair before, that was my sense too.
sbmmm is offline
Old 09-06-2020, 06:06 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,921
Maybe a "Vault" to cover the added plumbing that would be left FREE of concrete? And serviceable without a demo saw.....
Fouthgeneration is offline
The Following 3 Users Say Thank You to Fouthgeneration For This Useful Post:
Rio (09-06-2020), rrk (09-06-2020), sbmmm (09-07-2020)
Old 09-06-2020, 06:21 PM   #5
rrk's Avatar
Rewards Points: 32
I was involved with a job that was done that way, the connections were covered but accessible. it was in the wall behind the door close to the floor. Luckily the guy who did it was the original installer.
He accessed the original line past where the access point was going to be and peeled the pipes back to the access point to limit connections
rrk is online now
sbmmm (09-07-2020)
Old 09-06-2020, 09:47 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,629
I was thinking the same thing. A vault box to access the joints in case a leak occurs. Whatever floor covering you put in there would have to be removable for access. Kinda eliminates tile. Or it could be a destructive access, where you have to destroy the floor to get at the vaults.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-07-2020, 08:00 AM   #7
sbmmm's Avatar
Trade: General
Rewards Points: 32
Is your "vault" idea like a (metal) box in the floor with a removable cover for future access? And the spliced connections would be accessible in that box?
sbmmm is offline
Old 09-07-2020, 08:13 AM   #8
sbmmm's Avatar
Trade: General
Rewards Points: 32
What I need to verify is the exact path/position of the pipe. I don't own one, but I am going to rent a handheld thermal image camera from Homedepot and map it out.
Has anyone carefully chipped away at concrete to expose in-slab pex pipe? As I type this, I'm just wondering if the integrity of the post-demo pex "stubs" would be reliable even if I peeled enough back to put in a vault box.
EDIT: One additional question - Did that installer have to demo slab work and chip away concrete to expose and peel back the pipe?
sbmmm is offline
Old 09-07-2020, 09:11 AM   #9
rrk's Avatar
Rewards Points: 32
yes he did
he had an idea where pipe was but sprayed a little water on slab to get exact location
rrk is online now
sbmmm (09-07-2020)
Old 09-07-2020, 10:35 AM   #10
sbmmm's Avatar
Trade: General
Rewards Points: 32
yes he did
Interesting, thank you.
I'm guessing by spraying water on the slab pre-demo that the water reacted enough to heat coming from the pipes? Was that the idea or did the water indicate where the pipes were for some other reason?
EDIT: Or did the water dry faster above the heated pipes and leave "pipelines", kind of like a negative image on the wet slab?
sbmmm is offline
The Following User Says Thank You to sbmmm For This Useful Post:
rrk (09-07-2020)
Old 09-07-2020, 12:06 PM   #11
rrk's Avatar
Rewards Points: 32
yes
rrk is online now
sbmmm (09-07-2020)
Old 09-07-2020, 12:23 PM   #12
Texas Wax's Avatar
Rewards Points: 2,258
Yes done modifications to in floor radiant heat. Even have done copper to Pex loop back to copper with concrete over. One is over 15 years and no leaks.
You will have to make a connections in the floor and cover with concrete then run the new pex to an access vault-area for the zone valve. Best to do that in a wall, imo. And make dam sure your connections are made properly and don't cheap out on materials and equipment.
Or dig a hole under the slab and well do it all from underneath
Radiant heat in-slab help-_mg_0285.jpg   Radiant heat in-slab help-_mg_0264.jpg   Radiant heat in-slab help-_mg_0233.jpg
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
sbmmm (09-07-2020)
Old 09-08-2020, 07:27 PM   #13
Trade: Masonry
Why wouldn't you just install the valving UNDER a cabinet?????
The Following User Says Thank You to Fouthgeneration For This Useful Post:
sbmmm (09-09-2020)
Old 09-09-2020, 07:45 PM   #14
sbmmm's Avatar
Trade: General
Rewards Points: 32
Super good idea!
sbmmm is offline
