Question - HVAC - Contractor Talk
Question
Old 08-28-2014, 08:41 AM   #1
tyfattori's Avatar
Trade: Deck And Patio Installation
Rewards Points: 50
Question
I'm remodeling my house and in the bedroom I'm working on now there were recessed wall registers. They didn't sit flush with the drywall they sat back into the drywall. I removed the registers and I'm patching the hole with drywall when I noticed that the air duct needs to be moved away from the wall and in about an inch or two. What's the best way to go about doing this? In the basement the ceiling covers the duct work going into that bedroom. I've been searching but I can't seem to find anything specifically related to my question even on Google.
I took some pictures I'll attach to better explain my situation.
Thanks,
Tyler
tyfattori is offline
Old 08-28-2014, 10:35 AM   #2
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,952
Re: Question
I think the best way would be to open the ceiling below.
B.D.R. is offline
The Following User Says Thank You to B.D.R. For This Useful Post:
tyfattori (08-28-2014)
Old 08-28-2014, 10:46 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,568
Re: Question
Very annoying.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Agility (08-28-2014), tyfattori (08-28-2014)
Old 08-28-2014, 11:05 AM   #4
Agility's Avatar
Trade: Carpentry; Kitchen & Bath Reno
Rewards Points: 1,016
Re: Question
It looks like you have a floorboard there that is just waiting to come up to make room.
Agility is offline
The Following User Says Thank You to Agility For This Useful Post:
Old 08-28-2014, 11:54 AM   #5
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Question
Duct work is overrated
-Steve
TimelessQuality is offline
Old 08-28-2014, 11:54 AM   #6
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 158
Re: Question
http://www.installerstore.com/Baseboard-Registers.html
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Old 08-28-2014, 12:29 PM   #7
tyfattori's Avatar
Rewards Points: 50
Re: Question
I cut it back about an inch and a half just now with the sawzall so it fits now I just need to be able to move the actual duck forward.
Originally Posted by blacktop View Post
The one register that was there was a baseboard register but 8ft long. I really want to eliminate the whole baseboard register and put a flat 12x2 floor register.
I was trying my best to see if I could get it done without having to do that but if it has to be done it has to be done. Thanks for the replies. Anymore feedback is much appreciated.
Thanks
Old 08-28-2014, 12:42 PM   #8
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,490
Re: Question
Originally Posted by ScipioAfricanus View Post
Very annoying.
Andy.
I was wondering how he got that newspaper to stick to that wooden wall.
Delta
Old 08-28-2014, 12:44 PM   #9
tyfattori's Avatar
Rewards Points: 50
Re: Question
Delta
I didn't even notice that..
Old 08-28-2014, 12:44 PM   #10
Trade: Builder/GC
Re: Question
I'm not really understanding the problem.
You want to move the register out from the wall, without either accessing the ceiling from below, or taking up the floor?
Delta
Old 08-28-2014, 12:57 PM   #11
tyfattori's Avatar
Rewards Points: 50
Re: Question
Delta
Basically, I just want to know if I can go another route. I only have to move it in an inch and a half and actually a bit less because I wedged a piece of wood behind it and pryed it away from the wall a little bit. Taking up the floor would be a pita because the previous owner screwed down every single floor board with multiple screws through the whole house so I'm installing flooring over top.
Old 08-28-2014, 01:13 PM   #12
Drywall Slave
blacktop's Avatar
Rewards Points: 158
Re: Question
Looks like you need to bite the bullet and get your hands dirty !
Move It over?
blacktop is offline
Old 08-28-2014, 01:24 PM   #13
slowsol's Avatar
Rewards Points: 2,248
Re: Question
Are you a contractor?
-John
slowsol is offline
Old 08-28-2014, 04:10 PM   #14
tyfattori's Avatar
Rewards Points: 50
Re: Question
I'm the foreman for a landscape design company, we specialize in paver patios and custom decks.
Old 08-28-2014, 04:43 PM   #15
Agility's Avatar
Re: Question
Where does the duct originate from? It looks like you could pull that last floorboard and trim enough subfloor to adjust the duct.
Edit: If you're putting a new floor over the old one I would cut enough space to work comfortably and replace whatever you took out with fresh materials of the same combined thickness. Just don't cut through your joists.
Agility is offline
The Following 2 Users Say Thank You to Agility For This Useful Post:
B.D.R. (08-28-2014), tyfattori (08-28-2014)
Old 08-28-2014, 04:49 PM   #16
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Question
pull the register off.
let the heat go under floor.
you'll have a hot air radiant floor. DONE
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 08-28-2014, 05:19 PM   #17
tyfattori's Avatar
Rewards Points: 50
Re: Question
I'm actually going to go this route, I'll post some pictures when I finish. Thanks for the feedback.
Old 08-29-2014, 05:02 AM   #18
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,168
Re: Question
That would actually be a code violation.
beenthere is offline
Old 08-29-2014, 12:21 PM   #19
tyfattori's Avatar
Rewards Points: 50
Re: Question
I went through the floor and there was a spot in the basement where I could actually slide the ducting all the way back. I cut about 3 inches off and attached it with some self tapping screws and then wrapped it with foil tape.
**sorry if my pictures come out sideways**
Old 08-29-2014, 12:25 PM   #20
tyfattori's Avatar
Rewards Points: 50
Re: Question
One down, one to go next one is a bit more complicated.
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 55 01-20-2017 11:48 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
