New Construction W/ Radiant And Central A/C - HVAC - Contractor Talk
Old 11-14-2019, 09:14 AM   #1
vtboy51's Avatar
Trade: Electrician
I'm planning my next new build. I know I want radiant heat in basement and garage floor, but also want central A/C. I don't want to use the mini splits or high velocity systems for A/C. What are my other options? Do I really need to install a boiler and furnace to get both??
vtboy51 is offline
Old 11-15-2019, 08:44 AM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 560
Re: New Construction W/ Radiant And Central A/C
You don't need a furnace, just an air handler for the AC. It might not cost less though.
Golden view is offline
Old 11-16-2019, 06:27 AM   #3
builditguy's Avatar
Rewards Points: 1,932
The last one we did was a very small amount less. The customer decided to go ahead and install a furnace as well.
Radiant heat is great, but it also takes a while to warm up and cool down. If you wake up and it's chilly in the house, turning on the radiant heat, won't warm you up, right then. It will take quite a while. Whereas if you turn on the furnace, the house will be warm in about 20 minutes. (I'm guessing on time to warm up)
It's also good for those times when you have a cold spell. Might be 40 degrees for a few days, but warming back up after that. Those are times they use it.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
Golden view (11-16-2019)
Old 11-16-2019, 07:17 PM   #4
nickelec's Avatar
Trade: professional licensed electrician
Rewards Points: 454
I just did my house with radiant heat on every floor and central ac, I ran a 3/4 loop for a hot water coil in the Attic where the air handler is to have forced hot air for back up, I live in NYC and it gets pretty freaking cold.here so far it works wonders I haven't needed to put the forced hot air on yet
Sent from my SM-G965U using Tapatalk
nickelec is online now
Old 11-17-2019, 09:31 AM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 144
I would forgo the furnace portion & do as nickelec did (I assume he did an exchanger & not just looped coil). As for a boiler - it may not be necessary, you may actually be able to get by with a regular water heater but that requires some calculations which you need to do anyways so you not only get enough heat but don't overheat.
How are you doing ventilation air - stand alone ERV/HRV, tied into HVAC system, or other?
SLSTech is online now
Old 12-03-2019, 11:30 PM   #6
nickelec's Avatar
Rewards Points: 454
Update heat is on
Old 12-04-2019, 01:03 AM   #7
edward trowelhands
Trade: Diplomat
Rewards Points: 560
I had radiant as my sole heat source in Fairbanks Alaska with -50 degree weeks. No issues keeping up, but it's all about the heat loss. I had a well insulated home.
Old 12-04-2019, 07:57 AM   #8
nickelec's Avatar
Rewards Points: 454
Agreed so far I haven't needed the hot air back up , my house is completely spray foamed so heat loss is very minimal
