Need To Reduce HVAC Duct - Building Day Bed - HVAC - Contractor Talk
Old 12-07-2018, 06:49 PM   #1
guilamontagne's Avatar
Rewards Points: 6
Hello!
I'm a carpenter/cabinet maker, so I need some advice on HVAC.
I'm building a day bed in the nook you can see in the picture attached. I want to bring the air vent all the way the front of this space (flush with the entrance). The existing vent is connected to a 8" duct that connected to the furnace.
I am thinking about reducing the portion that will be under the bed to a 6" duct so it takes less space under the day bed.
Is there any problem to reduce this kind of duct from 8" to 6"? Maybe, there's too many factors to answer that question, but I'm trying...
Thank you!
guilamontagne is offline
Old 12-07-2018, 07:11 PM   #2
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
Re: Need To Reduce HVAC Duct - Building Day Bed
reducing and adding distance... won't be the same that for sure.
you could use some square ducts... like a 4x10.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 12-07-2018, 07:14 PM   #3
MarkJames's Avatar
Rewards Points: 19,391
Are the dimensions 8x3? Maybe change to 6x4. The main issue is restricting the air flow of the HVAC and whether it will suffice to condition the space.
MarkJames is offline
Old 12-07-2018, 08:05 PM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,530
The duct is placed at the window for a reason. The supply washes the wall and mitigates the heat loss/gain....but whatever..?
Steve
We Fix Houses is offline
Old 12-07-2018, 08:56 PM   #5
avenge's Avatar
Rewards Points: 302
Agreed this is the issue, but if I had to do it I'd go with 4x10 and put some extra blankets on the daybed.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
cedarboarder (12-07-2018), guilamontagne (01-01-2019)
Old 12-08-2018, 02:02 AM   #6
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,252
As long as you don't need cooling/air conditioning, that would work.
But its best to keep it 8" if the room is to be at the same temp as the rest of the house.
beenthere is offline
Old 12-08-2018, 02:42 AM   #7
test
Trade: General
Rewards Points: 815
why run ducting at all. ac bed.
Old 12-08-2018, 12:40 PM   #8
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Increasing the temperature differential between the inside of the window verses the outside which then exponentially increases the air infiltration.
They're put under windows because "that's how it was always done", "less tall furniture in front of windows" and most importantly "everybody *knows* it makes the the room warmer... maybe.
P42003 is offline
Old 12-08-2018, 12:47 PM   #9
beenthere's Avatar
Trade: HVAC
It does help keep the room warmer.
Back in the 40s and the 50s, supplies were put on the inside wall. Many people would complain about the sudden coolness they felt when the heat shut off. And how cold they felt sitting at the outside wall. In the 60s they started changing to supplies under the windows, and those types of complaints were reduced to almost none of that type.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
cedarboarder (12-08-2018), Tinstaafl (12-08-2018)
Old 12-08-2018, 04:34 PM   #10
test
Trade: General
Rewards Points: 815
If the house was in a cold climate I would say hell no.
Unless you like frosted windows that condense and causing mold along with rot....
The Following User Says Thank You to cedarboarder For This Useful Post:
P42003 (12-08-2018)
Old 12-08-2018, 04:42 PM   #11
Business Owner
P42003's Avatar
Rewards Points: 158
That's not an appropriate comparison. You're comparing floor supplies to wall supplies, and the floor supply is almost always superior to a mid-wall supply due to a decrease in stratification, regardless of its location around the perimeter.
P42003 is offline
Old 12-08-2018, 05:12 PM   #12
beenthere's Avatar
Trade: HVAC
When on an inside wall, a floor supply doesn't make the outside wall area feel anywhere near as comfortable as a floor supply on an outside wall does.
But either way, it doesn't matter, as the OP has a wall supply.
Old 01-01-2019, 03:53 PM   #13
Rewards Points: 6
Thank you, Sorry for my late reply. It's a 10" flexible duct attached to a 10 x 4 vent. I'm thinking extending the 10" duct underneath the bed for 3 feet. I guess it's not going to restrain the air flow much. House is in Oakland so not much frost in the windows anyway.
Old 01-01-2019, 05:24 PM   #14
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,835
Have the bumpout surveyed with a thermal camera. Fix the heat leaks...
Upgrade the windows to R-6 or better with a storm window and maybe thermal shades?....
Check for appliances that use internal instead of outside air for combustion, like fireplaces, old style furnaces,hot water heaters and ovens, They worsen the situation by 'Sucking' in Cold air.
Make sure your duct work is to code BEFORE changing it..
DO the math on the current setup, you might need MORE ducts, not fewer.
If your furnace is oversized, and never runs nearly full time at Max delta Ts, a smaller output furnace could run a lower CFMs fan speed, that would make the existing ducting/plenums "larger"...
If you so re-size your furnace, don't forget the effects of wind at Max cold.
I've used remote wireless thermometers that are part a cheap "weather station" to collect data on cold/ hots that record highs and low temps.
I'd consider installing the bed/furniture a few inches higher to leave ample room for air out or in, A space to collect the "wild" dust bunnies.
Fouthgeneration is offline
Old 01-01-2019, 07:23 PM   #15
beenthere's Avatar
Trade: HVAC
3 foot won't hurt anything.
storage building needs, buy or build? Ohio painter General Discussion 11 05-06-2018 11:50 AM
Commercial/Industrial HVAC Project Management veritasnic HVAC 2 05-19-2016 11:37 PM
HVAC Question About Furnace Duct Insulation mef526 HVAC 2 02-25-2014 04:55 PM
HVAC Heat Duct / Pipe Passing Through Vapour Barrier mattpalmeris Insulation 1 11-20-2011 10:23 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 02:37 PM
