Make Up Air - Page 2 - HVAC - Contractor Talk
Make Up Air
Old 03-15-2013, 08:37 AM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,368
Re: Make Up Air
Originally Posted by Hardly Working View Post
Wow this is becoming a pretty good thread.
I called my HVAC guy today (that's an Eng.) and after spewing all kinds of math calcs. at me he said wait till they get the heating bill. You not only need make up air but heated make up air. If it's in the 30's it wont take long to cool that house down in just a few minutes. We're talking an extra 45K of BTU in addition to what the house already has.
This can also become an issue when it comes to reselling the house. Is the new homeowner really going to want to spend an extra $30 to cook dinner when they turn the hood on? If it's drawing that much air it's more than likely to suck up grease vapor and collect in the hood. Now let's think safety and fire suppression. He said you could be talking between $4-$12 per CFM. Tell the HO to stop shopping at the discount restaurant supply. 500 CFM should be fine he said.
With that said I no nothing about HVAC. That's why I call him! Basically you've got a big can of worms there. Best of luck and let us know how it turns out.
Aren't even the crappiest of HRV's over 60% efficient?
Inner10 is offline
Old 03-15-2013, 09:24 AM   #22
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,522
Re: Make Up Air
If the range isn't a commercial one, why not simply open a nearby window (with fan energized) when cooking with oil? K.i.s.s.
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
griz (03-15-2013)
Old 03-15-2013, 11:04 AM   #23
Thom
thom's Avatar
Rewards Points: 4,748
Re: Make Up Air
It all depends on the location of the make up air. The closer the air source is to the vent hood the less heat/cooling will be needed. This is one reason many commercial units have the make up air supplied as part of the exhaust hood.
My recommendation for putting the make-up air at the range, possible on the wall behind the range is for just that reason. If you are exhausting unconditioned air that is supplied at the range you won't need much if any additional conditioning.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 03-15-2013, 12:49 PM   #24
Inner10's Avatar
Re: Make Up Air
wrong thread....ignore
Inner10 is offline
Old 03-15-2013, 04:25 PM   #25
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,188
Re: Make Up Air
HRVs exchange air. They remove X amount of air, and they bring in almost the same amount of air. So it wouldn't be enough to use as make up air.
beenthere is offline
Old 03-15-2013, 05:49 PM   #26
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Make Up Air
They make these MUA systems in up to 10" for resi. It looks like they were specifically designed for when high volume kitchen vent hoods are installed. Can't say I've ever installed one of these myself though.
http://www.ccbinnovations.com/the-product
DuMass is offline
Old 03-16-2013, 09:19 AM   #27
Thom
thom's Avatar
Re: Make Up Air
Looks like someone is selling that power activated damper I was talking about. Of course that still does not solve the location thing but it does allow for make-up air when the range hood is on.
thom is offline
Old 03-16-2013, 09:33 AM   #28
beenthere's Avatar
Trade: HVAC
Re: Make Up Air
And if the OP's draft hood would actually remove 900 CFM, he would need 2 of the 10" ones. Plus he would need to increase the furnace size by rough 60,000 BTUs, and a 30,000 BTU increase for the A/C.
Old 03-16-2013, 11:16 AM   #29
DuMass's Avatar
Trade: EC
Re: Make Up Air
On that end of things, I wonder if they may be able to use duct heaters or get approval to use something like one of the commercial all-in-one units with a duct heater/filter/fan for their resi application.
Seems like a lot of expense for a trophy kitchen that probably won't even get used. I believe if they just go with a 400 CFM or less hood then they wouldn't even be required to provide make up air, but I'd have to double check on that to be sure.
DuMass is offline
Old 03-16-2013, 11:23 AM   #30
beenthere's Avatar
Trade: HVAC
Re: Make Up Air
Many of those resi hoods rated at 600 plus CFM are ducted that the don't even move 300 CFM.
Those that move close to their rating are seldom used more then a few times when the MA is connected to the central heat/AC system, Since the other rooms can end up getting cold or hot. And the opening to the kitchen becomes a air tunnel no one wants to walk through. And then when they get the heating or cooling bill they either stop using the hood, the MA, or have both derated.
The Following User Says Thank You to beenthere For This Useful Post:
flashheatingand (03-16-2013)
Old 03-16-2013, 02:06 PM   #31
bconley's Avatar
Trade: Kitchen and bath design+remodel
Re: Make Up Air
Originally Posted by txgencon View Post
Seems like you're close to the threshhold of commercial kitchen equipment.
It will be interesting to see if anyone can give you any specifics here.
Good luck.
1200cfm range hoods are all too common in high end residential kitchens.
We have tied a a servo air damper to the hood fan switch in a duct from the outside to under or behind the range.
Code here says if you keep it under 600 CFM no make up air is required.
bconley is offline
The Following User Says Thank You to bconley For This Useful Post:
thom (03-17-2013)
Old 03-16-2013, 03:28 PM   #32
Hardly Working's Avatar
Rewards Points: 812
Re: Make Up Air
While talking with my HVAC Eng. he told me of a time when someone did put an over sized hood in and they thought the dog was digging in the fireplace. Turned out the fan was sucking air down the chimney and sucking the ash into the room.
Homeowners and their grand ideas. They see this chit on TV or someones home with no idea what it take to put it in and when you tell them the cost they think your a thief.
Hardly Working is offline
Old 03-16-2013, 04:37 PM   #33
Inner10's Avatar
Re: Make Up Air
Any reason why you couldn't run your vent hood through a charcoal filter then into an HRV?
I had a friend try it with a dryer and it lasted about 3 weeks until it was completely clogged with lint.
Inner10 is offline
Old 03-16-2013, 04:44 PM   #34
beenthere's Avatar
Trade: HVAC
Re: Make Up Air
You would have to also add a grease filter to prevent it from clogging. Plus would still need an additional 24,000 to 30,000 BTUs for heating, and 12,000 to 18,000 BTUs of additional cooling.
Old 03-16-2013, 04:48 PM   #35
Inner10's Avatar
Re: Make Up Air
Hmmm...what if you ran the exhaust through a filter then back into the house and then exhausted an HRV near by to freshen things up?
Inner10 is offline
Old 03-16-2013, 05:27 PM   #36
beenthere's Avatar
Trade: HVAC
Re: Make Up Air
What if they always go out to eat and never use the exhaust hood. Never need make up air then.
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
Need to make DIY Bug Screens, please help finakat Windows, Siding and Doors 8 05-19-2012 07:36 PM
Make Code Books Free 10fingers General Discussion 35 07-18-2009 10:59 AM
