Looking For Info On Extending A Trailer Furnace (oil) Chimney (pipe) - HVAC - Contractor Talk
Old 08-02-2011, 04:03 PM   #1
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
Like the title says, I just built basicaly a pole barn over a trailer and I need to extend the furnace exhaust pipe, up 42" just to get through the roofing, then how ever far I have to go above that.
Of course being a trailer furnace, the pipes are odd size, the center is 4 1/2" and the large outer pipe is 10 1/2". It only sticks up about 4" off the origonal trailer roof.
Just wondering what you pro's have done if you've ever had to do it.
I am thinking using heavy wall 5" and making it fit, then using 10" over it as a double wall system?
thanks,
dave
dave_dj1 is offline
Old 08-02-2011, 06:56 PM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Re: Looking For Info On Extending A Trailer Furnace (oil) Chimney (pipe)
The space between the 4.5" and 10.5 inch is where the burner gets its combustion air from. So you can't make the space smaller, or yo won't get enough combustion air.
beenthere is offline
Old 08-02-2011, 07:49 PM   #3
dave_dj1's Avatar
I understand what you are saying but that is not the case with this one, the 10" is capped off, and only sticks up above the origonal roof by about 3". I'm guessing the furnace will need a tune up after the taller pipe is put on.
I will call a couple of oil companies in the hood tomorrow and see what they have to say.
dave_dj1 is offline
Old 08-02-2011, 07:55 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,006
Try an RV supply place?
griz is offline
Old 08-03-2011, 07:42 AM   #5
MechAcc's Avatar
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Rewards Points: 150
Get the make and model number of the furnace. You must use the manufactures extension kit.
But, before you do have the furnace inspected and checked. If the heat exchanger leaks or is cracked there is no sense buying an extension kit for a defective furnace.
MechAcc is offline
Old 08-03-2011, 07:43 AM   #6
MechAcc's Avatar
Rewards Points: 150
MechAcc is offline
Old 08-03-2011, 05:03 PM   #7
dave_dj1's Avatar
Well I talked to a reputable place today that specializes in mobile homes and got the 411 on what to do.
It's a miller trailer furnace that has been retro'd in.
Thanks for the responses.
dave_dj1 is offline
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
Flue cap GettingBy HVAC 11 02-14-2011 04:46 PM
Fresh air duct work for oil furnace 3Rivers HVAC 14 12-07-2010 06:27 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
