HVAC Water Leak Driving Me Nuts - HVAC - Contractor Talk
Old 06-17-2018, 05:44 PM   #1
Ancient Mariner's Avatar
Trade: Residential GC
Rewards Points: 6
Hi All!
I have an HVAC issue I can't figure out. My 1st floor inside air handling unit is in the basement. It's been filling the pan with water, and kicking off the AC when the float switch trips. I thought it might be a faulty pump (mine isn't gravity draining, drains into a pump and pumps outside). Pump works fine. Then I thought my drip line was clogged. I snaked it, still fills the pan. Next I thought maybe the line is partially clogged. Snaked again and separated the pvc drain piping and put a funnel in line so I can see it dripping, just to monitor. Always dripping when the AC is running, no problem.
I can check on it for days and it doesn't fill up; until it does again.
Then I thought; maybe the pump housing has a slow leak. It leaks out faster than the drain drip, slower than the speed I filled the pump when I find the pan full and manually fill it. Took it out and ran it on a clean surface; no leaks.
Anybody seen this before?
Thanks!
Ancient Mariner is offline
Old 06-17-2018, 08:35 PM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,248
Re: HVAC Water Leak Driving Me Nuts
Maybe the pipe from the pan to the pump is bottoming out in the pump reservoir ? Cut the line at 45 deg or secure it up from the bottom of the reservoir.
Addl - you say float switch and pan ? The pan below the unit is a secondary catch pan. How is the primary draining, if at all ?
Steve
We Fix Houses is offline
The Following 2 Users Say Thank You to We Fix Houses For This Useful Post:
Ancient Mariner (07-03-2018), flashheatingand (06-17-2018)
Old 06-17-2018, 10:10 PM   #3
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,522
Is it possible the leak is at the coil? Coil draining proper? Secondary drain either plugged? Open to the atmosphere? Or is there a condensate safety switch on the secondary outlet ?
Is this a leak issue? Or is this a condensate pump issue?
http://www.37flash.com/
flashheatingand is offline
Old 06-18-2018, 06:15 PM   #4
Rewards Points: 6
Thanks We Fix Houses! When I got home from work, no new water (not unusual). I cut the 45 and reinstalled like you said tonight and will keep an eye on it.
Thanks FlashHeatingandAir! Would those causes show no symptoms for days and dump the water all at once like this seems to be doing? It does over flow my pan into the floor, which I though was odd since the cutoff float switch seems to be working.
If it happens again, I'll check out the coil, secondary drain and condensate pump.
Old 06-19-2018, 07:12 PM   #5
VinylHanger's Avatar
Rewards Points: 10,936
I have a similar situation, so hope I can hop on this thread.
I'll post a picture of what I have. I know less than nothing about HVAC, it's not my system, just the remodel I'm on and would like to wait until we are closer to being done to get the HVAC guys in.
It's a gas furnace/air handler. No water in the auto float, ez-trap.there is a bit of water under it, but I can't feel any on the pipe above it.
It looks like the box thing on the side is filling up and spilling over. Is tthis a pump of some kind?
VinylHanger is online now
Old 06-20-2018, 09:31 AM   #6
Trade: H.v.a.c.
Vinyl, it does not appear that water is leaking from the pump assembly. is the safety switch on the pump connected to the system? It looks as if water the water is coming from below the "drop-box" under the indoor coil.
You mention a remodel. Is it possible you have dirty air filters from all the dust?
Old 06-20-2018, 11:22 AM   #7
The box is completely full. I ran it all day, but it was full in a few hours.
I changed the filter at the intake in the house. I will look for one on the air handler when I get there today.
Will dirty filters cause this?
Old 07-03-2018, 04:36 PM   #8
Rewards Points: 6
Steve @ We Fix Houses,
Your suggestion to cut a 45 degree angle in the drain pipe where it goes into the pump did the trick. I haven't had a leak in 2 weeks since I did this.
Thanks!
Chris
The Following User Says Thank You to Ancient Mariner For This Useful Post:
flashheatingand (07-04-2018)
Old 07-03-2018, 08:01 PM   #9
OK good deal...glad to help
Steve
Water Leak Sensor For Vacation Rental Sammy_242 Plumbing 5 09-12-2017 09:44 AM
Low Water Pressure creating a faucet to leak? srwcontracting Plumbing 3 08-21-2012 11:32 PM
Water line leak S.R.E. Excavation & Site Work 3 07-27-2012 10:29 PM
