Hey Pro HVAC'ers
I have a house I am working on and the AC unit is driving me crazy it is around a 2ton Puron/Carrier I believe. One air handler one condensing unit. The Heat is part is using Nat. Gas ( not heat pump)
The issue is that for 2-3 week the unit runs fine. Then the Air handler is running. The condensing unit out side is not on. Replaced contactor and Capacitor just to make sure they are fresh. When the out side condensing unit is not running and the air handler is running. Now its happening Pretty much all the time. The Air handler turns on the condensing unit sometimes turns on or does not but it will then only run about 3 minutes. Turn off breakers for about 20 minutes. Rinse repeat.
Is the FAN bad maybe pulling to many amps getting too hot? Compressor ?
The computer on the system messed up ? It is a 2 zone system with a damper.
FSCHRIS
FSCHRIS
