How Do I Make An Existing AC Unit Quieter? - Page 2 - HVAC - Contractor Talk
Old 09-26-2018, 07:46 AM   #21
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,254
Re: How Do I Make An Existing AC Unit Quieter?
Originally Posted by beenthere View Post
The loud noise, is a sign of an under sized duct system, or incorrect register/grille selection by installer.
This is what my HVAC guy stresses all the time. You can't even tell my heat or AC is on. I feel like that's the way it should be.
Golden view is offline
Calidecks (09-26-2018)
Old 09-26-2018, 02:42 PM   #22
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
What size unit is it? Air handler will run 400cfm per ton. How many and what sizes are your return air grills? I can hear mine running but its not bad, I have a 4 ton and have a 24x30 in the ceiling by the thermostat and a 12x12 in my bedroom with plans to add another on the other side of the house.
I have my first 2 stage system with a variable speed air handler in my new house and absolutely love it. When it runs on 1st stage only you can't even tell its on.
SuperiorHIP is offline
Old 09-26-2018, 02:49 PM   #23
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,602
That's funny you mentioned that I'm in the process of adding a 16x24 as we speak.
Mike.
_______________
Calidecks is online now
Old 09-26-2018, 04:09 PM   #24
GC/carpenter
Calidecks's Avatar
Hey gentlemen meet me over in the things I hate thread.
Mike.
_______________
Old 09-26-2018, 04:13 PM   #25
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,429
Might make it worse if the ducting can't handle the extra velocity/CFMs. Think I read the main trunk should be around 600-700 fpm
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-26-2018, 06:59 PM   #26
Tom M's Avatar
Rewards Points: 3,534
I thought oversized units short cycle and the right size unit can become oversized if you upgrade other house RValues.
So insulated duct line is no longer an option, how about a canvas transition off the truck to absorb echo vibration?
Tom M is offline
Old 09-26-2018, 07:06 PM   #27
avenge's Avatar
Rewards Points: 624
Replace it all with true variable speed you'll love it.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Fouthgeneration (10-01-2018)
Old 10-01-2018, 11:37 AM   #28
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,337
Use the wall cavity as an duct, add return vent above existing ones =slower air flow = quieter.
Build a Air filter box(6"x24"? floor to ceiling) on the room side of existing grillage to create a labyrinth sound reduction. install sound dampener material on at least two sides of cavity.
Consult HVAC guide to duct sizing to see where you went off the Reservation with air speed...
Add floor return duct under the furnace box that communicates with poorly served rooms...
How long does the system run during max cooling ~2:00 pm mid summer?, If less then 50 % of the time, you could swap the oversized A coil and outdoor condenser for smaller unit that needs less CFMs.
Are any rubber motor or fan mounts missing or damaged?
Do you have a isolating plenum connector, so the entire ductwork isn't a giant speaker cone for furnace vibs....
Is the Fan DIRTY/ out of balance? Loose belt, dying bearing?
A kink in the refrigerant lines creating a nasty harmonic/whistle noise?
Buy a larger stereo?
Fouthgeneration is offline
Old 11-11-2018, 03:17 PM   #29
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,516
From the picture that I see, it looks as if you are drawing all the air from the hallway,and the side. It doesn't help that the furnace is in the middle of everything, inside of the living space.
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
Calidecks (11-11-2018)
Old 11-11-2018, 06:28 PM   #30
Trade: Masonry
Installation manual: https://aplusair.ca/wp-content/uploa...ion-Manual.pdf
Check out the "door" for attic mounting is not in position...
Lower fan speed one or two steps.
Old 11-11-2018, 10:42 PM   #31
GC/carpenter
Calidecks's Avatar
It's drawing from the hall, kitchen and formal dining room on the other side.
Mike.
_______________
Old 11-11-2018, 10:43 PM   #32
GC/carpenter
Calidecks's Avatar
I can completely remove the return grills and it's still very loud. The registers are not that bad.
Mike.
_______________
Old 11-11-2018, 11:07 PM   #33
hdavis's Avatar
Rewards Points: 3,132
I've had some pretty noisy blowers from time to time. I've also picked up whistles and other noises from air bypassing the air filter.
I'm assuming you're using a high efficiency filter, so there will be a pretty large pressure droo across it.
You may be able to do some sound deadening in there without restricting flow too much.
hdavis is online now
Old 11-11-2018, 11:22 PM   #34
GC/carpenter
Calidecks's Avatar
I took the filter out to see if that's the issue. Didn't get quieter.
Mike.
_______________
hdavis (11-12-2018)
Old 11-11-2018, 11:34 PM   #35
LRG WoodCrafting
Leo G's Avatar
Winter makes my AC much quieter.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 11-12-2018, 12:30 AM   #36
Frank Castle's Avatar
Rewards Points: 920
Me Too!
Thanks Leo, I needed a good laugh.
Adapt, Improvise, Overcome.
Frank Castle is online now
Old 11-12-2018, 04:25 AM   #37
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,182
Making and post a recording of the sound/noise so we can here what it is.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Calidecks (11-13-2018)
Old 11-12-2018, 07:58 AM   #38
Tom M's Avatar
I was told by a tech that the inducers are noisy. Some worse than others.
Tom M is offline
Old 11-12-2018, 08:05 AM   #39
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,096
Some units are just loud. In my first house I had a brand new Payne and it was LOUD. You had to pretty much yell over it while you were in the basement to communicate. Heat and ac.
Big Johnson is offline
Old 11-12-2018, 08:38 AM   #40
Fixed's Avatar
Trade: HVAC
Rewards Points: 196
One of the big selling points for the higher end units is often how many dB they produce.
Sent from my SM-G935W8 using Tapatalk
Fixed is offline
Paving adjacent to existing roadway sniff26 Concrete & Paving 3 04-24-2016 09:41 PM
Metal Roof over existing Asphalt Canada_Ryan Roofing 19 10-22-2015 07:16 AM
Latest Wall Unit Roger Manning Carpentry Picture Post 13 05-18-2015 03:47 PM
1927 Oliver 117-A Bandsaw Restoration..... PrestigeR&D Tools & Equipment 49 01-12-2014 11:35 AM
Veneering / Enertainment Unit Build J.C. Finish Carpentry 17 12-08-2012 09:52 PM
