How Do I Make An Existing AC Unit Quieter? - HVAC - Contractor Talk
Old 09-25-2018, 10:48 AM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,242
Here's my AC unit. Sounds like a jet taking off. I'm wondering if there's a thermostat to turn down the fan speed. Thanks guys go easy on me I'm just a carpenter.
Mike.
_______________
Calidecks is online now
Old 09-25-2018, 10:55 AM   #2
GC/carpenter
Calidecks's Avatar
Re: How Do I Make An Existing AC Unit Quieter?
Sits right behind my TV.
Mike.
_______________
Old 09-25-2018, 03:38 PM   #3
sefiroxx's Avatar
Trade: remodel/handy
Rewards Points: 152
. . .turn it off . . .
sefiroxx is offline
Old 09-25-2018, 04:30 PM   #4
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,901
Unplug it, don't need it here until next May.
rescraft is offline
Old 09-25-2018, 04:58 PM   #5
META's Avatar
Trade: General and Trades
Rewards Points: 7,158
I know some blower motors can be wired for lower speeds but if the internal motor wiring isn't proper, they will burn out quicker.
META is online now
Old 09-25-2018, 06:44 PM   #6
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 452
Strictly speaking, what you are showing is the FAU and not what most consider to be the A/C unit. That is usually the condensing unit located outside.
The FAU is gas fired so you need combustion air of course, so I might recommend taking combustion air via a 7" tube from the attic area then you can insulate the door and that might mitigate a lot of the sound from the squirrel cage.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Calidecks (09-25-2018), griz (09-25-2018)
Old 09-25-2018, 06:47 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 2,006
you sure the unit/fan is functioning as designed?
griz is online now
Old 09-25-2018, 07:11 PM   #8
sefiroxx's Avatar
Rewards Points: 152
Googled it up : http://new.ncshvac.com/?product=59sc5a080s17-16
Describes fan speed option but with special thermostat.
Some hacks:
- not enough vent space below the unit. May have to add low in the hall. Would reduce the whooshing sound
- if the blower is that loud, could drop some sound absorption material on the floor in the vent duct. But, would chaise potentially bad blower or repair first.
sefiroxx is offline
The Following User Says Thank You to sefiroxx For This Useful Post:
Fouthgeneration (10-01-2018)
Old 09-25-2018, 08:20 PM   #9
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Some hacks:
Fan speed option is for continuous fan only. heating and cooling speed are fixed. But can be adjusted to a lower setting.
The loud noise, is a sign of an under sized duct system, or incorrect register/grille selection by installer.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-25-2018, 08:28 PM   #10
MarkJames's Avatar
Rewards Points: 19,057
I'm with Mike on this inquiry. We've got a newly installed air handler that is doing similar....seems too damned loud due to the intake at the main return.
MarkJames is online now
Old 09-25-2018, 08:41 PM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 10,033
You say it sounds like a jet. Is it the sound of the motor or the sound of the rushing air?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-25-2018, 09:48 PM   #12
MarkJames's Avatar
Air, i'll wager
Old 09-25-2018, 10:09 PM   #13
GC/carpenter
Calidecks's Avatar
Sorry guys, just got in from a long day today.
Yes, it's air. There's three return air vents. The sound of air pulling from the vents, and I've completely taken the grill off. It's still louder than ****.
Mike.
_______________
Old 09-25-2018, 10:11 PM   #14
GC/carpenter
Calidecks's Avatar
The unit is only about 3 years old. Or home gets cooled down quickly, no doubt.
Mike.
_______________
Old 09-25-2018, 10:12 PM   #15
LRG WoodCrafting
Leo G's Avatar
No blockage? Has it always been this way? If yes to both it sounds like the CFM being pulled is to large for the openings.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-25-2018, 10:12 PM   #16
GC/carpenter
Calidecks's Avatar
To clarify, the registers in the rooms are quiet. It's just the return air under the FAU.
Mike.
_______________
Old 09-25-2018, 10:13 PM   #17
GC/carpenter
Calidecks's Avatar
No blockage, and yes it's always been this way.
Mike.
_______________
Old 09-25-2018, 10:17 PM   #18
LRG WoodCrafting
Leo G's Avatar
Well do some science. Measure the total output area by adding up the square footage of the registers. Then do the same for the returns. They should be the same or the returns should be bigger.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-25-2018, 10:34 PM   #19
LRG WoodCrafting
Leo G's Avatar
Do you have a 4 ton AC unit (48000 BTU)? Because at full speed (1600 CFM) that's what it's rated for. That's a pretty big AC unit. Usually a house is 2.5 ton.
That's what I run in the shop.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-25-2018, 10:47 PM   #20
GC/carpenter
Calidecks's Avatar
I want to say it's a 5 ton. I'll look tomorrow.
Mike.
_______________
Paving adjacent to existing roadway sniff26 Concrete & Paving 3 04-24-2016 09:41 PM
Metal Roof over existing Asphalt Canada_Ryan Roofing 19 10-22-2015 07:16 AM
Latest Wall Unit Roger Manning Carpentry Picture Post 13 05-18-2015 03:47 PM
1927 Oliver 117-A Bandsaw Restoration..... PrestigeR&D Tools & Equipment 49 01-12-2014 11:35 AM
Veneering / Enertainment Unit Build J.C. Finish Carpentry 17 12-08-2012 09:52 PM
