Honeywell Zone Valves - HVAC - Contractor Talk
Old 01-12-2019, 11:16 AM   #1
MarkJames's Avatar
Rewards Points: 19,393
Radiator heat.
We just charged up our two-zone hydronic heating system after a year of remodeling. When either zone (thermostat) calls for heat, now both loops are circulating freely, not just one. This wasn't the case prior to the remodel. The zone valve levers are in the left/ (closed) position for both, even though the heat calls are circulating water through both loops. Do Honeywell zone valves break in this fashion, or does it sound like something else entirely is going on?
I will call back the Plumber/HVAC guy, but he's the one that said everything was operating fine yesterday. Just trying to get some understanding ahead of time.
Thanks.
MarkJames is offline
Old 01-12-2019, 12:00 PM   #2
hdavis's Avatar
Rewards Points: 1,920
Re: Honeywell Zone Valves
Do they both show voltage to them when only one zone is calling for heat?
hdavis is online now
Old 01-12-2019, 12:08 PM   #3
MarkJames's Avatar
Unsure, but I'll check later.
Still, the valve is not being operated with setting changes, just appears to be always "closed"...yet water is still cycling through both. (Now wondering what the valve guts look like.)
Old 01-12-2019, 12:57 PM   #4
hdavis's Avatar
If they'e like Taco, closed isn't the right way to think about it. There is manual open, and then there is control actuated, what you're calling closed.
The actual actuator is wax that expands when heated and opens the valve.
Old 01-12-2019, 01:13 PM   #5
hdavis's Avatar
Most commonly, the wax actuator gets weak over time, and the valve stays closed. I suppose if the valve was manually opened for an extended period, it could get stuck open.
MarkJames (01-12-2019)
Old 01-12-2019, 01:15 PM   #6
MarkJames's Avatar
I recall the motor whirring to operate the valve (and move the lever). Something's probably up with the wiring, though it is firing up the boiler and Taco circulator pump.
hdavis (01-12-2019)
Old 01-12-2019, 01:27 PM   #7
hdavis's Avatar
Just checked, honeywell is motor driven, not wax driven. That makes troubleshooting potentially a little more complicated.
Sounds like a wiring issue.
honeywell 3way normally open zone valves IamSparky HVAC 6 12-19-2010 10:31 AM
wiring a honeywell zone valve threequez HVAC 2 11-11-2009 04:28 PM
low voltage transformer for Zone valves. kiffys General Discussion 3 12-07-2007 07:16 AM
how do troubleshoot a Honeywell Zone valve? [email protected] HVAC 9 12-01-2007 06:36 PM
Zone valves and transformers mdshunk HVAC 3 05-13-2007 09:49 PM
