Honeywell 3way Normally Open Zone Valves - HVAC - Contractor Talk
Old 12-18-2010, 10:46 AM   #1
IamSparky's Avatar
Trade: Iam a Maintenance Director for a nursing home
Question
I am a Maintenance Director for a nursing home and we have the above honeywell zone valves. My question is can someone explaing how each port is to be hooked up to the system. This particular valve has a 208 volt coil and is normally open. which port is supposed to be the supply and return etc. thank you
IamSparky is offline
Old 12-18-2010, 02:50 PM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Re: Honeywell 3way Normally Open Zone Valves
That depends on its application.
So what are you using the valves for.
beenthere is offline
Old 12-18-2010, 04:59 PM   #3
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
With a 3-way valve, one side will always be open to the common port while the other side is closed.
On those smaller Honeywell valves, arenít the individual ports marked with A, B and AB?
Port AB is common and port A or B will be open or closed to it, depending on the position of the diverter.
DuMass is offline
Old 12-19-2010, 07:26 AM   #4
IamSparky's Avatar
thank you
Old 12-19-2010, 07:31 AM   #5
beenthere's Avatar
Trade: HVAC
Yes. And what the valve is being used for determines how it is positioned. And how it is controlled.
The Following User Says Thank You to beenthere For This Useful Post:
IamSparky (12-19-2010)
Old 12-19-2010, 10:27 AM   #6
DuMass's Avatar
Trade: EC
True. I assume these are on the hot and chilled water loops for a fan coil where you can generally see the line supplying the coil, so that should generally indicate which position a replacement valve needs to be in.
The Honeywell and larger Barber Coleman valves with hydraulic actuators, all had spring return, so that, along with the temperature changes of the piping should also help in determining the NO/NC positions of a deenergized diverter valve that is already installed.
DuMass is offline
Old 12-19-2010, 10:31 AM   #7
beenthere's Avatar
Trade: HVAC
Yes it should.
I've seen that valve used, for many things. Some set ups had 2 valves(4 pipe system) and it was easy to over look that the one valve was installed turned the opposite way of the other.
Last edited by beenthere; 12-19-2010 at 02:46 PM. Reason: should have been 4 pipe not 3 pipe
wiring a honeywell zone valve threequez HVAC 2 11-11-2009 04:28 PM
low voltage transformer for Zone valves. kiffys General Discussion 3 12-07-2007 07:16 AM
how do troubleshoot a Honeywell Zone valve? [email protected] HVAC 9 12-01-2007 06:36 PM
Zone valves and transformers mdshunk HVAC 3 05-13-2007 09:49 PM
