Heat For Shed - HVAC - Contractor Talk
Heat For Shed
Old 11-24-2007, 06:24 PM   #1
SHORTGUN's Avatar
Rewards Points: 75
Heat For Shed
I would like to put heat in my shed but am unsure of what the best heating system would be for my shed.
I am insulateing it and it is 200 sq.ft..
It has 110 electeic in my shed.
SHORTGUN is offline
Old 11-24-2007, 07:30 PM   #2
tinner666's Avatar
Rewards Points: 1,000
Re: Heat For Shed
i'm gonna use the heat from my OWB to heat my shed, shop, and house.
For just a shed, one of those 110v oil filled radiators should be OK. At least 3 heat settings on them.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 11-24-2007, 07:34 PM   #3
SHORTGUN's Avatar
Rewards Points: 75
Re: Heat For Shed
Will they heat a area of 200 sq.ft. in Northwest Ohio? It gets cold here.
SHORTGUN is offline
Old 11-24-2007, 07:40 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,038
Re: Heat For Shed
It should as long as it is insulated.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 11-24-2007, 08:55 PM   #5
Teetorbilt's Avatar
Rewards Points: 2,000
Re: Heat For Shed
Small wood stove?
Albert Einstein
Teetorbilt is offline
Old 11-24-2007, 09:11 PM   #6
oldfrt's Avatar
Rewards Points: 94
Re: Heat For Shed
Consider a small direct vent propane unit,or depending on the time you will spend there,even pellet stove.
oldfrt is offline
Old 11-25-2007, 10:38 PM   #7
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
Re: Heat For Shed
I use a wall hung propane for my garage, uninsulated and it works fine.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 11-26-2007, 06:43 AM   #8
Al Smith
A W Smith's Avatar
Re: Heat For Shed
First a floor thread then an insulation thread now a heat thread
so how long did she kick you out for?
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 12-01-2007, 06:38 PM   #9
BigMikeB's Avatar
Trade: HVAC
Rewards Points: 150
Re: Heat For Shed
Propane infared, the best way to go for the size of that
BigMikeB is offline
Heat Exchanger Problem with Hayward Pool Heater jtc1062 Pool Construction & Enclosures 6 10-24-2007 09:33 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 09:13 PM
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 05:05 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
