Heat Pumps - HVAC - Contractor Talk
Heat Pumps
Old 09-21-2010, 06:49 PM   #1
Superheat's Avatar
Trade: Oil Gas AC
Heat Pumps
New to the trade, but i have a heat pump qusetion. With a Split system with an air-handler in the attic Who manufactures the most efficeint equipment out there? The next question, carrier, reem, bryant, all have a 19 seer unit but they say they dont want it to operate if its 55 deg or below is there another manufacturer that will go lower?
Thanks
Superheat is offline
Old 09-21-2010, 07:02 PM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Re: Heat Pumps
Thanks
The size also determines how much efficiency you will get. The model line will be "up to 19 SEER". But the 5 ton units may only reach 15.5 or 16.5 SEER.
I think you have that 55 degree think misconstrued. It may be if the house is less then 55 degrees inside.
beenthere is offline
Old 09-21-2010, 07:40 PM   #3
Superheat's Avatar
Trade: Oil Gas AC
Re: Heat Pumps
I'm bad, Carrier Infinity, home owners manual states do not run your ac when the out side unit is 55 or below and do not run your heat pump when the out side is 66 or above. So how low can this equipment go and still give you heat?
Old 09-21-2010, 07:45 PM   #4
beenthere's Avatar
Trade: HVAC
Re: Heat Pumps
Some -10F, some -20F, and 1 brand, -30F.
The Infinity I believe is -10.
Dual Fuel Heat Pumps Lisa6801 HVAC 17 01-11-2011 07:54 PM
It's getting hot out there, people......... 480sparky Health & Safety 9 07-11-2010 07:23 PM
heat pump jdager HVAC 2 01-31-2009 04:17 PM
Heat Pumps naturenut HVAC 3 01-27-2006 02:03 AM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
