-   HVAC (https://www.contractortalk.com/f6/)
-   -   have a rheem handler, do i have to have a rheem condenser (https://www.contractortalk.com/f6/have-rheem-handler-do-i-have-have-rheem-condenser-422643/)
woodspike 10-07-2019 08:02 PM
got a 3 ton 2107 rheem , handler on a remodel job.( abandoned building ,, i`m gutting )
i`d like to upgrade my house which happens to be 3 ton unit . but probably 1990-95)
i know my condenser is very old , breaks down a lot , i have to push the rest button a few times a month
question , do i have to have a rheem condenser , or can i get a different name condenser if the handler is rheem?
whats best?
i`ll have an a/c guy put it in , but if i can get it there , i`ll save a few $$
don`t want to ask him these questions
Mike-B 10-07-2019 08:13 PM
Doesn't need to be the same manufacturer. Capacity and refrigerant types should be the same
Sent from my SM-G970U using Tapatalk
Leo G 10-07-2019 09:05 PM
Unless the unit has a proprietary electronics communication system between the handler and compressor you should be fine. Might want to get a new TXV valve.
woodspike 10-16-2019 08:44 PM
thank you for that
Fouthgeneration 10-17-2019 02:17 AM
Different pressure rating for "new" refrigerants?
I have no clue as a Mason.
Fan speed might need to changed, make sure drain/drip pan is clean on evaporator coil.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
