Goodman Pressure Switch - HVAC - Contractor Talk
Old 02-09-2012, 09:28 AM   #1
Chippewa's Avatar
Trade: HVAC
I replaced the heat exchanger on a goodman 90% last night. When I went to start the furnace the pressure switch that sees the pressure from the cover of the condensate pan was not making. I bypassed it and ran it for about fifteen minutes. At that point the pressure switch was making so I placed the furnace back into normal operation. About two hours later the homeowner called back with the same problem. I am sure the pressure switch is good, but I did not have a negative pressure guage on me at the time so I am not sure what the pressure actually was.
Chippewa is offline
Old 02-09-2012, 10:58 AM   #2
Doc Holliday's Avatar
Trade: hvac
Re: Goodman Pressure Switch
Clear the flue pipe and/or the ports where the pressure switch TUBE connects to on the draft inducer motor and the pressure switch as they could have crud in them. Stick an unfolded paper clip into the ports where the tube connects to clear them out.
The drain line could have condensation/crud in it as well which would not allow the pressure switch to close.
Did you seal the heat exchanger properly?
Doc Holliday is offline
Old 02-09-2012, 12:52 PM   #3
Chippewa's Avatar
Trade: HVAC
The heat exchanger came as a whole unit, meaning the primary, secondary, front cover, and drain pan were all one piece. The tube in question feeds off of the secondary heat exchanger cover and should pull a -.75. There is an additional switch that also pulls a -.75 which pulls directly off of the wheel housing. I switched the switches and the problem did not move so I am sure it isn't the switch. I did try and clear out both the tube and the tap. Since the unit came as one piece I am really not sure what could not have been sealed properly. I do know it is pulling a vacuum but I am not sure as to what specific number it could be. Voltage flows (or doesn't flow right now) through the switch directly into the gas valve so the code is a failure to fire. I really didn't check the condensate line well. With everything being new I don't think it is build up. It never fired from the start either so I don't think it is back up. I will be going back tonight with a gauge so I can see what vacuum it is pulling, but I am at a lose as to my next step. I feel as though I am missing something since the pressure switch was not a problem before I took the old exchanger out.
Chippewa is offline
Old 02-09-2012, 01:44 PM   #4
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Take a look at the solder joints on the back of the control board. Goodman has had problems with cracking solder joints on their boards.
http://www.37flash.com/
flashheatingand is offline
Old 02-09-2012, 08:49 PM   #5
Chippewa's Avatar
Trade: HVAC
I am getting 24 volts at the switch though. It just isn't closing.
Chippewa is offline
Old 02-09-2012, 11:00 PM   #6
Dr Heat
Dr Heat's Avatar
Trade: hvac
Rewards Points: 306
I had A Heil that had a pressure switch issue after a heat exchanger. The end result was grease from the manufacturing process had plugged the secondary. Had to pull the secondary and poor hot hot water on it for a long time to get the grease to melt out. The whole process took several trips and many many hours.
Dr Heat is offline
Old 02-10-2012, 08:20 AM   #7
Chippewa's Avatar
Trade: HVAC
That sounds like the problem I may be dealing with. Thanks, I will give that a try.
Chippewa is offline
Old 02-10-2012, 09:46 AM   #8
Trade: H.v.a.c.
If that is the case, I would want a new furnace. That shouldn't be a burden that the h/o or the repair guy should hold. If you can prove the heat exchanger was cracked and the replacement exchanger was faulty as well, the burden lies with Goodman, or whomever.
That being said, I would make sure the nipple
port on the h/e is is clear. It sounds like you have quite the pickle and would love to hear the outcome.
Old 02-19-2012, 04:25 AM   #9
greenleafmech's Avatar
Trade: HVAC
Rewards Points: 81
Did you get this heat exchanger under warranty? Did you also check the warranty disclosing on this particular furnace?
Furnace repair and AC repairs in Chicago
http://www.greenleafheatingandcooling.com
greenleafmech is offline
Old 02-19-2012, 08:54 AM   #10
Chippewa's Avatar
Trade: HVAC
I did get the heat exchanger under warranty. When I went back with a magnehelic the pressure was fine. I decided to let it run and just see what happened. It has been over a week and it is still working fine.
Chippewa is offline
Lennox Pressure Switch Trouble? Glock23 HVAC 3 11-18-2012 11:11 AM
Pressure switch sticking jkfox624 Plumbing 11 08-18-2011 05:15 PM
10 Ton Goodman RTU gas pressure problem. hvactech140 HVAC 14 01-08-2011 10:31 AM
air pressure switch mistermcfrug HVAC 2 07-28-2010 06:40 PM
How to Safely Pressure Wash Your Home. PressureWashE Pressure Washing 1 07-02-2010 05:50 AM
