Goodman Condensing Unit - Page 2 - HVAC - Contractor Talk
Old 04-16-2012, 12:05 AM   #21
Doc Holliday's Avatar
Trade: hvac
Re: Goodman Condensing Unit
Btw jesse, you may want to practice your brazing on some scrap copper. You're using way too much heat if you're burning the seals in the valves.
Not an insult of any kind, I'm just saying.
Doc Holliday is offline
The Following User Says Thank You to Doc Holliday For This Useful Post:
flashheatingand (04-16-2012)
Old 04-16-2012, 06:29 AM   #22
jesse5's Avatar
Trade: hvac
for sure on that one i rember when i first started we used flux and solder didnt have cordless drills either thanx my friend
jesse5 is offline
Old 04-16-2012, 04:59 PM   #23
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,202
Might want to see if the liquid line service valve has the same problem first befoe swapping out the vapor side. If it does, then do both at the same time, and save yourself some work later.
May not be your brazing. Some of those valve are real cheaply made.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
jesse5 (04-16-2012)
Old 04-16-2012, 07:26 PM   #24
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Maybe jumped the gun on how you braze. Don't think your the first guy to over-heat a valve or so. Just one simple tip, use a wet rag. Reason being is that wet rag helps in absorbing the heat, so, keep the valve body wrapped in a wet rag.
http://www.37flash.com/
flashheatingand is offline
condensing boiler water heater combo unit builditright Plumbing 1 02-10-2011 09:05 PM
complex sound insulation -duplex on incline desertsound General Discussion 4 12-03-2010 01:04 AM
Goodman Units are leaking freon BiggersJunior HVAC 24 01-21-2010 08:19 AM
odd Goodman package unit problem airwick HVAC 3 07-17-2008 10:36 PM
goodman condensing unit control wires Unregistered HVAC 5 10-28-2004 05:12 AM
