Gas Regulator??? - HVAC - Contractor Talk
Gas Regulator???
Old 11-02-2010, 07:08 PM   #1
Sparrkky2's Avatar
Trade: Electrical
Angry
Gas Regulator???
A Carrier furnace about 10 years old.
Over the past few weeks I have had numorous problems starting with the porcelain ingnitor going bad, once replaced, the main board was bad (which may have caused the ignitor to crap out),replaced the board and for a few days it was fine.. then heard noises like small explosions from the furnace. Through the site glass i could see the furnace come on as normal and after a minute or 2 the flames would just about disappear and re-ignite causing the explosive sound. The 24volts to the regulator was never interrupted unless it was too quick to see on my meter. Ive gently tapped on the regulator thinking something was restricting the flow... but still not help.. ANY IDEA??
Mike
Sparrkky2 is offline
Old 11-02-2010, 09:10 PM   #2
The Flooring Guy
cork-guy's Avatar
Trade: Flooring
Rewards Points: 250
Re: Gas Regulator???
When I got to this point I decided you should seek HVAC professional help for safety reasons;
Cork Flooring - Educational information on cork flooring for consumers
Cork Flooring Twitter | Cork Flooring Facebook | Ventless Fireplace
cork-guy is offline
Old 11-02-2010, 11:54 PM   #3
hvacrman's Avatar
Trade: hvac and refrigeration
Rewards Points: 25
agree
hvacrman is offline
Old 11-03-2010, 07:38 PM   #4
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
I probably wouldn't wait for the big explosion. Better to call for service than to have to call the Fire Dept.
DuMass is offline
Old 11-03-2010, 09:12 PM   #5
hvacrman's Avatar
Rewards Points: 25
i missed this the first time and hopefully you called an hvac contractor by now ,but who determined those parts were bad ?
hvacrman is offline
Old 11-04-2010, 04:13 AM   #6
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,202
I'm gonna subscribe to his local newspaper. So I can read about it.
beenthere is offline
Dial regulator kell490 Sandblasting 1 10-01-2010 09:12 PM
Voltage regulator? woodchuck2 Electrical 10 09-25-2010 11:43 PM
Compressor Problem -- Regulator? Young_Buck Tools & Equipment 20 07-16-2010 07:44 PM
Repair Pressure Regulator mrmike Plumbing 3 01-20-2009 11:29 AM
draft regulator mrmike HVAC 3 01-18-2009 10:40 AM
