Hope to get some advice. My MIL furnace is sputtering. It starts out small and short and eventually the sputters get longer and then it finally times out from lack of flame.
Fresh oil, no water in the system, clean filter and screen. I've replaced the old transformer with a new electronic spark device. Last year we had the system pumped dry of fuel and then new fuel with an anti-water additive.
It's been doing it for quite some time now, a few seasons. I've had "the guy" come by several times and all they ever do is a tune up, filter, screen and nozzle. Even if the guy hears the sputtering he calls it done. Obviously time for a new guy.
So I had a sputtering problem on my system many years back and it ended up being sludge in the line. I used compressed air and blew out a 2' long snake of sludge and that cleared up my problem.
So after trying most normal things I finally blew out the inlet line to her 1000 gal underground tank. I didn't want to do it because of fear of blowing the line and causing real work. But I put pressure into the line and found little if any resistance.
I connected things back up and the furnace hasn't run this good in quite some time (after the initial bleeding), but it is still doing small intermittent sputters. So as the furnace was running I opened the bleeder valve until I got a small steady stream. Every time a sputter occurred I could see a break in the stream.
Mean anything?
I haven't checked the pressure of the pump yet (A2VA-7116 Suntec). It is suppose to be 100psi nominal.
If the pressure is low, could this cause the piston/spring to shut down the flow and cause the sputter? Can it be as simple as raising the PSI on the pump to over come the spring pressure to keep the oil flow constant? A new pump is about $80 and I don't really feel like throwing unnecessary parts at it. But I can't really think of what else it can be if it wasn't a clogged inlet line.
Any words of wisdom for me? Well, besides find another guy to look at it :laughing:
Break in the stream, as in air bubbles? If you hook up clear plastic tubing to the bleeder, you'll see the bubbles if there are any. Otherwise, you're just having a drop in volume.
Looks like the stream breaks. Doesn't look like bubbles. And if it is they are really big.
I'm thinking the pressure drops and cuts off the piston which stops the flow.
I found a 0-160PSI 1/8" NPT meter at the shop. I'm going to put it on the pressure test port and see what it says. Hoping it's in the high 80s which would make the pressure low and make it hard for the pump to open it. Crank the pressure up and it should stop the problem.....maybe.
Otherwise I have an air leak in the line somewhere or the pump is on it's way out.
Went back there with a pressure gauge and hooked it up to the Pressure Gauge Port. Fired up the furnace and for the first few seconds it's nice and steady. After that it's jumping +/- 10PSI. When the unit shuts down I think the pressure is suppose to drop 10-20%. It drops to 10PSI and leaks down to zero rather quick.
The only think I'm unsure about is if the port is the same as the nozzle output. I watched a few youtube videos and I think they connected directly into the nozzle port.
If at the port, pressure should drop to zero almost instantly. Keeps fuel from dribbling out and making a smoking dangerous mess.
Only been 50 years or more since I worked on one. I recollect those things would get boogered up with black crusty crud #2 fuel oil just naturally leaves behind.
Ya, I just watched one of the vids again using the manifold tester and they connect it to the nozzle port and then use a valve to shut down the flow to the nozzle. This way it can maintain pressure within the system to check if you have backflow leakage through the regulator.
FWIW, you can clean most of the crud out of the system periodically by putting diesel in when the tank is almost empty, then running that. The next thing to do would be a filter change....
A worn gear pump would fail to produce pressure required as it warms up... new oil is much thinner then legacy bunker oils of the past and have much less sulfur as lube for low cost pump parts :sad:
Check vent on tank for blockage or air "leaks" on any suction lines
most likely a valve seat or spring has nearly failed reducing output pressure/volume below minimum needed for steady firing, check burner orifice for partial blockage/ bad spray pattern?
100.00$ for a new pump and or regulator is much cheaper than a midnight in December repair bill....
That's pretty much what I don't want to hear. But I've been coming to that conclusion myself.
What I don't understand is it was really bad before I blew air through the suction line and after I blew air through it, it was 90% better. Now you can't hear the sputtering, you can only see it on the gauge. Whereas before it would time out the furnace it was so bad.
What I'm thinking is there is a small air leak somewhere in the middle of the line. There was a 80-90% blockage at the oil tank, the beginning of the line. I blew out the line and felt little to no resistance, but that doesn't mean I didn't blow out 2 or 3" of sludge at the start of the line. Now, without the sludge there the air leak is under a lot less vacuum when the pump is pulling oil. So now I'm getting a lot less air in the line because it's a lot more free flowing.
The problem with the air leak is it'll cost her $10-20 grand to get that tank out of the ground, clean up and put a new tank somewhere in the basement. She's broke.
All I know, is here in MI, the road #2 fuel has to be colored, so that when MDOT pulls you over they know if you been cheating using oil bought from the home delivery guys.
It's about $0.26/gal road tax here.
the stuff used at the gravel pits is just plain old #2 fuel oil.
Related Threads
3.5M posts
151.3K members
Since 2003
