Furnace Making Homeowner Sick - Page 2 - HVAC - Contractor Talk
Old 10-15-2014, 04:49 PM   #21
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Furnace Making Homeowner Sick
Originally Posted by Peewee
Does it make you ladies feel important to simply reply? I'm in south texas where oil is not the fuel, but what any fossil fuel needs in this instance is an escape route. Does your car have an exhaust pipe? So how's yours on the furnace and what kind of furnace was installed? Natural draft or induced? single stage 80% or condensing? I could go on but I'll await a reply... Come on now..
Seeing you have 6 posts, and based on your snarky comment are clearly green. This is a community where we talk about a lot of things. I find I learn way more from the derails then the original thread it's self.
So to your question. I don't feel special. You clearly do. But I just got paid to post this. :cheers:
jlsconstruction is offline
Old 10-16-2014, 09:39 AM   #22
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
To the op. I would suggest taking apart the exhaust pipe where the elbow goes up the chimney / riser. Yesterday, we replaced an oil furnace with gas. The furnace wasn't all that old. When I disconnected said joint, the elbow was almost filled with soot, which led to poor combustion...etc.
At least get the firing analyzed to make sure all is well in that aspect.
http://www.37flash.com/
flashheatingand is offline
Old 10-16-2014, 12:30 PM   #23
Buildtech's Avatar
Rewards Points: 47
Thanks to everyone for the great suggestions. I think an air quality test is the next logical step. I'll keep you posted.
Buildtech is offline
Old 10-20-2014, 08:05 PM   #24
coolmen's Avatar
Trade: hvac
Rewards Points: 79
I would check the static pressure of the hvac system to see if there are major duct problems.
coolmen is offline
Rheem Classic 90 Plus Furnace control panel accident boos HVAC 4 01-26-2013 01:30 PM
Furnace Troubleshoot Cache HVAC 7 01-25-2013 07:48 PM
Stuck on "down" goodman (pac) furnace ,got 8 hrs 2 fix!! (1ST TIMER) duramax79 HVAC 8 01-21-2013 11:11 PM
Fresh air duct work for oil furnace 3Rivers HVAC 14 12-07-2010 06:27 PM
