Extending Ceiling Ducts - Drop Ceiling - HVAC - Contractor Talk
Old 02-13-2020, 04:20 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 478
A suspended t-bar is going in, means the ducts and covers need to go lower.
Do they make extenders? I've heard they do but can't seem to locate.
Prefer not to drop the assembly on the upper tile for support (insulation between joist, copper running below one, etc).
artinall is offline
Old 02-13-2020, 04:26 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 606
Re: Extending Ceiling Ducts - Drop Ceiling
The "extenders" you refer to are lengths of duct you cut to length.
Remove the boots, cut duct to length and re-install.
Support the extended boot w/guy wire to the framing.
griz is offline
artinall (02-13-2020)
Old 02-13-2020, 04:35 PM   #3
artinall's Avatar
Rewards Points: 478
I thought the boot outlet is same as standard duct size?
artinall is offline
Old 02-13-2020, 04:38 PM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,108
It's not uncommon for the final couple feet of duct to the diffuser to be flex duct.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Old 02-13-2020, 08:50 PM   #5
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,212
Buy a straight boot/boots, 90 el/els and buy flex duxt/flexible duct connector. Remove boot. Put on 90 El. Run flex from El to New boot.
beenthere is online now
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-13-2020, 08:51 PM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 864
Take the 90 boot off, install an elbow and a straight boot.
Big Johnson is online now
Old 02-13-2020, 08:56 PM   #7
Rewards Points: 864
Looks like bt beat me.
https://www.menards.com/main/heating...72-c-14260.htm
https://www.menards.com/main/heating...17-c-14260.htm
Old 02-13-2020, 09:13 PM   #8
artinall's Avatar
Rewards Points: 478
With the flex duct, what keeps the boot from falling?
Seems like I need a pair of metal rails on tile topside.
artinall is offline
Old 02-13-2020, 10:58 PM   #9
TheConstruct's Avatar
Rewards Points: 1,410
I'd put a rigid elbow on it and then rigid ducting to just above the ceiling tile level. Look for a 5 inch round diffuser which will just spring into the rigid ducting. Trying to keep a grill in the ceiling tile is a losing battle.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
artinall (Yesterday)
Old Yesterday, 06:47 AM   #10
Rewards Points: 864
That would work too but you want 6” and one that closes for the summer.
Old Today, 07:56 AM   #11
beenthere's Avatar
Trade: HVAC
Duct ties keep the flex on the El, and the boot on the flex.
You can also make up rails for it if you prefer. Commonl done.
