Evaporator Cleaning Methods - HVAC - Contractor Talk
Old 06-25-2011, 09:55 AM   #1
greengenius_A_C's Avatar
Trade: HVAC
Hey guys. Just trying to take a poll. When you suspect a dirty evaporator, do you bother with the chemicals (and maybe a shop vac at the same time to prevent dripping onto a heat exch.) and water rinse while the evaporator is still in the air handler?
Or do you drag the coil outside ANY time it needs cleaning?
Just wondering if I can save some time by doing it inside...
Thanks.
greengenius_A_C is offline
Old 06-25-2011, 04:14 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Re: Evaporator Cleaning Methods
Personally, I try to stay away from chemicals. If you are hardcore, you can pull out the heat exchanger and get good access. Otherwise, I will use a long garden hose (if in the garage). Granted, my first choice is to pull out the coil as a whole, but usually, that isn't possible.... Oh, you are talking about upflow? Can't you pull the coil out.
I prefer to not open the system and remove the coil altogether, too many things that can go wrong.
http://www.37flash.com/
flashheatingand is offline
Old 06-25-2011, 07:15 PM   #3
Trade: HVAC
So you're saying your first choice is to pull the coil out (unsolder the connections and take it outside and hose it), but you're also saying that you prefer not to do that because too many things can go wrong. If the hose is long enough, sometimes you will bring the hose into the garage or into the house and just wash the coil without removing it from the air handler?
I don't like break out the torch if I don't have to.
Old 06-25-2011, 08:06 PM   #4
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
As long as the coil is not already completely choked up, Iíll find a way to hit it with Enviro-Coil, biodegradable, no rinse cleaner and let the coil sweat take care of the rest.
DuMass is offline
Old 06-25-2011, 08:20 PM   #5
Trade: HVAC
What is your definition of completely choked up? The flashlight test? Or you mean a visible layer of dog fur?
Old 06-26-2011, 08:15 PM   #6
DuMass's Avatar
Trade: EC
No hard and fast rule, simply a case by case basis. A peak with the
9mm SeeSnake can usually give an idea of what condition the coil surfaces are in. If that matted dog fur is present, I donít think Enviro-Coil cleaner is going to remove it.
DuMass is offline
Old 06-26-2011, 08:50 PM   #7
Trade: H.v.a.c.
Sorry about being unclear. When I said pull out the coil, that did not mean, un-solder the pipe, simply pull it out so that you can brush & clean.
Hose inside the house, not a good idea either, but in the garage, usually, it's ok.
Old 06-27-2011, 12:20 AM   #8
Trade: HVAC
Gotcha. For some reason when you said pull it out I assumed unsoldering would be a given because the line set doesn't really compromise much if you were to try to move the a-coil.
I've been looking into those duct access panels with cams or hinges as an add-on for future evaporator inspection/service. I don't know if anyone else really uses them much, but it would be nice to have a door to the evaporator instead of just a foil-taped square of sheet metal. Not a bad upsell either I suppose...kidding!
Old 06-27-2011, 07:46 AM   #9
Trade: H.v.a.c.
Around here, most coils are cased. So inspection isn't a problem. The problem is access to giving the coil a good cleaning. Frequently the lineset is routed across the front panel, and those w-coils are really hard to brush.
That's why I mentioned pulling the heat exchanger (downflow). With an impact drill, heat exchanger replacements really aren't that tough. But, when it's 90+ outside and calls are backing up, it may not be feasible.
Old 06-27-2011, 11:30 AM   #10
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
Would a small garden style pump up tank do for spraying a coil down with water or chemical?
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 06-27-2011, 10:39 PM   #11
Trade: H.v.a.c.
Those pumps are nice for dampening a coil. But, they have their limitations
Old 06-30-2011, 09:51 PM   #12
Trade: H.v.a.c.
I bought a toilet brush last spring, and that has been a great tool for cleaning coils as well.
Old 07-11-2011, 09:31 PM   #13
MechAcc's Avatar
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Rewards Points: 150
Refrigeration Technologies makes a NSF Evaporator Cleaner, Viper E+, that is an enzyme. Seems to work fairly well. Self rinsing. Can be used in Food Facilities.
The intro to Captain Carbonex Video now shows the other coil cleaners. http://www.youtube.com/watch?v=o9TVMcqZ69U
MechAcc is offline
Old 07-20-2011, 04:50 AM   #14
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,246
Thanks, I gotta check their stuff out.
beenthere is offline
Maximum efficiency framing crew size and methods UpNorth Framing 9 01-19-2011 03:17 PM
Heat Exchanger Inspection Methods Symposium MechAcc HVAC 3 08-15-2009 01:10 PM
Assembly methods willworkforbeer Finish Carpentry 16 05-27-2009 08:54 PM
Methods to square a walkout foundation FRAMERBEN Framing 18 03-09-2009 12:12 AM
