Dumb Question - HVAC - Contractor Talk
Dumb Question
Old 02-12-2012, 10:42 AM   #1
dayexco's Avatar
Rewards Points: 218
Dumb Question
walked out back of house today, saw an icicle hanging from my pvc furnace vent coming through the sill plate of my house. not big at all, was NOT obstructing the pipe whatsoever. i assume this is common? this something i need to have my furnace guy look at? he does a spring A/C, fall furnace checkup for me and didn't say anything. don't want to bother him if i don't need to.
dayexco is offline
Old 02-12-2012, 10:52 AM   #2
Tom M's Avatar
Rewards Points: 3,474
Re: Dumb Question
Its normal. High efficency furnaces condense thats why they use PVC and direct vent them. I hear what your say though, it looks like it can eventually build up and block the whole vent.
Tom M is offline
dayexco (02-12-2012)
Old 02-12-2012, 11:35 AM   #3
Stewy's Avatar
Trade: home improvements and renovations
Rewards Points: 87
Re: Dumb Question
I think the pvc pipe should slope back to the furnace to prevent this. Could it be a drip from the roof line that hits the pipe and forms the ice?
Stewy is offline
Old 02-12-2012, 11:39 AM   #4
Tom M's Avatar
Re: Dumb Question
Its most likely the sloping away from the furnace that is causing the slow drip to freeze up as it closer to the outdoors.
Tom M is offline
Old 02-12-2012, 12:15 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
Re: Dumb Question
yep, I had my 90+ heater for about the last 12 years - every year same icicle and I'll just knock it off when it gets to big. Pipe is configured correctly and install was top notch.
No worries though...if it blocks you'll be the first to know when the heater shuts off...least i assume so anyway with the newer equipment
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
flashheatingand (02-13-2012), rex (02-15-2012)
Old 02-19-2012, 04:02 AM   #6
greenleafmech's Avatar
Trade: HVAC
Rewards Points: 81
Re: Dumb Question
There is supposed to be a pitch in the pipe, but in very cold climates the water doesn't have a chance to drain back to furnace and it starts building icicles. We've had to go to jobsites to clear this ice as sometimes it builds up and it renders the furnace from working properly or at all.
Furnace repair and AC repairs in Chicago
http://www.greenleafheatingandcooling.com
greenleafmech is offline
Another dumb question Hmrepairs Framing 2 11-14-2010 02:20 PM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
Chimney question guyute65045 Masonry 2 03-26-2010 09:31 PM
