Ductless Mini Split - HVAC - Contractor Talk
Ductless Mini Split
Old 05-30-2018, 12:03 AM   #1
Fire up the BBQ
griz's Avatar
Rewards Points: 2,982
Ductless Mini Split
Any of you guys have any experience with a mini split providing heat & A/C in your own home?
Rep says I need a 2 zone system and it will heat & cool my house with only 2 heads.
I'm skeptical.....
I have installed several mini splits but they are in computer server rooms and only have to cool.
griz is online now
Old 05-30-2018, 12:29 AM   #2
Designer/Contractor
Rio's Avatar
Rewards Points: 2,288
Re: Ductless Mini Split
2 would work with one in the bedroom, one in the living room but if one has more rooms one wants more heads; Depends on how big the house is, I like the 'more is better' technique.
Rio is offline
Old 05-30-2018, 12:50 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,418
Efficient, comfortable, quiet, steady heat or cool for a climate like yours. But 2 heads might be pushing it unless it's a VERY open floor plan or VERY well insulated.
Golden view is online now
Old 05-30-2018, 05:16 AM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,026
following.
Little Brother has a home in historic area with baseboard heat. Been talking to him about going from window units to something esle.
We are aging out - few more years and he won't be able to heft those window units.
SmallTownGuy is online now
Old 05-30-2018, 09:09 AM   #5
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,522
Depends on how many walls in the home. Great for open space heating and cooling. But if rooms are going to be closed off for privacy, or whatever reason, not so great.
The other reservation I would have is parts, should something fail. Finally, those cassettes aren't all that attractive, and take up a bit of wall space for decorating.
They have their advantages, especially if ducting isn't all that feasible. But, for the part, ducting is the best way to go if one needs both heating and cooling.
http://www.37flash.com/
flashheatingand is offline
Old 07-06-2018, 12:29 AM   #6
GreenTek's Avatar
Trade: General Contracting
Rewards Points: 26
I'm surprised some people are stating mini splits aren't good for closed space homes. I have customers that want cooling and heating in two focused areas such as a family room and a hot upstairs bedroom, and a 2 zone mini split worked wonderful for them and was much more cost effective than a whole home HVAC split system.
GreenTek is offline
Old 07-06-2018, 07:43 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,262
No forced air in the home?
Inner10 is offline
Old 07-06-2018, 09:27 AM   #8
Fire up the BBQ
griz's Avatar
yes, currently ducted split system heat pump.
its going to need replacement and was just looking at options
griz is online now
Old 07-06-2018, 10:07 AM   #9
Inner10's Avatar
Why the hell would you replace that with a mini split?
Inner10 is offline
Old 07-07-2018, 09:32 AM   #10
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
you've got my attention...I don't have help for you but I think i'm in a similar need situation.. My home is 1500 sq.ft. two story all open(no interior doors) what have you got going on and what have you learned??
...I was pondering just one unit to take the edge off days like yesterday
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 07-07-2018, 03:57 PM   #11
RickP's Avatar
Trade: Door Installer
Rewards Points: 450
I'very got a 1000 Sq foot log cabin that is a bit drafty. It's got a 36000 BTU Mitsubishi mini split with 3 indoor units. It does an ok job of cooling, but struggles to heat it when it under 45 degrees.
RickP is offline
Old 07-07-2018, 05:38 PM   #12
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,581
I just finished installing a DIY 12k BTU mini split last week. We choose to try a mini split after knocking down a couple of walls and throwing up a couple beams. The cost to install it was thousands less than installing dedicated ducts on exterior walls from the basement in a balloon framed house build in late 1890.
The brand was MRCOOL from Amazon. $1261.60 delivered. The install took me about 6 hours. The hardest part being running the 25' copper lines thru a knee wall, out the soffit, thru 3x4 downspout and connecting them without leaks or kinks.
The outdoor portion is pre-charged somehow and once connected via the copper lines you open two hex screws and it releases the refrigerant. The old window unit blew 66 while the new mini split blew 51. Tested with the same thermometer about 20 minutes apart. It was easily 90 degrees outside.
It works much better than the 18k BTU window unit it replaced. Its also whisper quiet. A local HVAC contractor that I have had good pricing from in the past quoted me $4450 for a Fujitsu 18k.
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
griz (07-07-2018)
mini split unit comes precharged? chillypilgrim HVAC 8 01-09-2016 08:42 PM
Mini Split Condenser under water rrk HVAC 5 04-20-2013 12:54 PM
Mini split leaking water JackP23 HVAC 1 04-19-2013 06:53 PM
Mini split New const. glkirk HVAC 3 04-15-2012 11:07 AM
mini split overloading Tom M HVAC 8 08-25-2011 11:38 PM
