Dryer Vent Connection - HVAC - Contractor Talk
Old 02-03-2019, 01:59 PM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 494
Does anyone have a good solution for dryer vent connections behind the dryer? There has to be a good way to get the dryer closer to the wall and not smash the flex. Any feedback on the Dryer Box?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 02-03-2019, 02:15 PM   #2
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,230
Re: Dryer Vent Connection
The last one I installed was the plastic Dundas Jafine one. Was pretty fiddly to install and not very good quality. If I were to do it again, I would look for a metal one like this https://dryerbox.com/choose.htm# Preferably it would be in a 2x6 wall so you don't have to do the oval pipe transitions.
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
DaVinciRemodel (02-03-2019)
Old 02-03-2019, 02:41 PM   #3
diplomat
Golden view's Avatar
Rewards Points: 696
I always use the dryer box. Works fine in a 2x4 wall, just squish the pipe a little. My inspector is fine with that method, yours may not be.
Golden view is online now
The Following 3 Users Say Thank You to Golden view For This Useful Post:
DaVinciRemodel (02-03-2019), flashheatingand (02-05-2019), overanalyze (02-03-2019)
Old 02-03-2019, 02:57 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,007
For existing laundry?
I approach these methodically, as in "whatever works this time", but keeping in mind ease of cleaning and reconnecting.
Sometimes a short length of flex is just the best.
Sometimes elbow + 2' hard + flex, if you need longer reach to connect (eg. tight closet).
Then there's the periscope box, which I've used a couple times (hard to line up when connecting in a tight space)
Maybe the best way would be to have the wall outlet recessed, but without an elbow (eg. pointing downward.) Then you would connect the flex to it.
MarkJames is online now
Old 02-03-2019, 03:19 PM   #5
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 58
We have used the dryer box for years, they finally made the 480 so it works up or down with or without pedestals.
https://dryerbox.com/db-480-versatility
I can't compete with hacks.
donerightwyo is offline
Old 02-03-2019, 03:25 PM   #6
Rewards Points: 494
That's the one I'm looking at. Thanks
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
donerightwyo (02-03-2019)
Old 02-03-2019, 04:02 PM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,034
I like doing the dryer boxes, makes a nice clean job out of it.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
DaVinciRemodel (02-04-2019), overanalyze (02-03-2019)
Old 02-03-2019, 04:47 PM   #8
avenge's Avatar
Rewards Points: 120
Any of them are better than the plastic ones.
avenge is offline
Old 02-03-2019, 05:23 PM   #9
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
That's the style I use, not sure of brand. Gets set approx 12" off the floor, because most new w/d combos now set on pedestals/boxes.
Even so, if the offset is too great, it still pushes dryer out.
SmallTownGuy is offline
Old 02-03-2019, 06:35 PM   #10
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,637
https://www.magvent-dryervent.com/
rescraft is online now
The Following 4 Users Say Thank You to rescraft For This Useful Post:
kevjob (02-04-2019), overanalyze (02-03-2019), Seven-Delta-FortyOne (02-04-2019), SmallTownGuy (02-04-2019)
Old 02-03-2019, 07:07 PM   #11
tjbnwi's Avatar
Rewards Points: 1,680
Magvent------ Solves every problem dryers present.
(I see rescraft bet me to the post [by a lot], he is absolutely correct)
tjbnwi is online now
rescraft (02-03-2019)
Old 02-03-2019, 07:29 PM   #12
Box Builder
Morning Wood's Avatar
Rewards Points: 10,280
The dryer box is good.
Morning Wood is offline
Old 02-03-2019, 10:35 PM   #13
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,160
Another fan of the Dryerbox...been using them for years. I really like the concept of the magvent too!
overanalyze is offline
Old 02-04-2019, 11:15 AM   #14
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,008
Never heard of that Mag-Vent till now.
Thing looks pretty sweet.
Does it work as well in real life as it does on the video?
Old 02-04-2019, 05:39 PM   #15
diplomat
Rewards Points: 696
Mag vent looks cool. Seems like dryers tend to move around a little. I could see it disconnecting. Though I suppose you'd notice soon enough.
Old 02-04-2019, 08:35 PM   #16
MarkJames's Avatar
Seems like the mag vent addressed a separate issue from the crushed flex problem. I'd probably crush it anyway if the holes didn't line up.
Old 02-04-2019, 08:35 PM   #17
MarkJames's Avatar
Old 02-04-2019, 08:37 PM   #18
Rewards Points: 494
You can say that again!
I was wondering how well-aligned things need to be with the Mag Vent. Can you buy a different dryer?
Old 02-04-2019, 09:56 PM   #19
tjbnwi's Avatar
Yes it does.
There is about 6" of flex duct on the dryer and the magnetic hub.
Old 02-04-2019, 09:58 PM   #20
tjbnwi's Avatar
Never seen one disconnect until you slide the dryer out. The magnet is pretty strong and the dryer helps hold it in place.
Dryer Vent Chenyi General Discussion 5 04-29-2017 08:33 AM
Dryer Vent overanalyze HVAC 10 11-19-2016 01:32 PM
Dryer vent pipe replacement. Builders Inc. General Discussion 18 02-10-2016 11:07 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
Dryer Vent Linked To A Waste Line Vent? JaeDotAre Plumbing 15 01-04-2012 01:45 PM
