Divide Room With Only One Register - HVAC - Contractor Talk
Old 06-21-2020, 08:22 AM   #1
MikeMc1's Avatar
Hi, my second floor is one large bedroom that I plan to divide with a wall. The main concern is the HVAC: there is only one hot air register (in the floor) and one return (on the wall).
The hot air register is centrally located and could be split to feed both rooms I suppose. But there's no way I can see to get a cold air return into the new room - which is on the opposite side of the house from the existing return.
I am sure there's concerns about splitting the register. Air flow is already inadequate. Also there's sound proofing concerns between the rooms if any sort of air sharing is done.
If we split the register, it would probably be done by converting the existing floor register into a flexible duct and then extending it.
I assume whatever we do, some baseboard heat supplement will be involved.
I am not a contractor. I am open to suggestion. Thanks.
MikeMc1 is offline
Old 06-21-2020, 09:06 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,018
Re: Divide Room With Only One Register
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is online now
