Dealer Cost For HVAC Units - HVAC - Contractor Talk
Old 01-19-2014, 10:27 PM   #1
Custom Home Builder
BiggersJunior's Avatar
Trade: Residential Custom Builder
Rewards Points: 75
I have been curious for a while about the actual cost for HVAC units. I am a builder. I have received 3 bids for a home and the range of the bids is unreal (varies up to 90% for the same units/items).
I am looking for the actual (ballpark) itemized cost for a Heil and/or Goodman 13 Seer 1.5 ton AND 2 ton units only? How many hours would it take to change them out? The HVAC contractor will use the existing duct work. Thanks for your help.
BiggersJunior is offline
Old 01-19-2014, 10:30 PM   #2
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Re: Dealer Cost For HVAC Units
Good luck.
rex is offline
The Following 2 Users Say Thank You to rex For This Useful Post:
accessheating (01-29-2014), dkillianjr (03-16-2014)
Old 01-19-2014, 10:33 PM   #3
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
I am not sure why but I am sure you could answer your own question as to why. Are you the most expensive GC in the area or the cheapest? Why? Now apply that answer to your question.
I understand your trying to not get ripped off and you want solid workmanship but if you have any questions about someones bid you should just ask them.
Meant no disrespect but the base of most all contractors and contracting is pretty much the same.
CrpntrFrk is offline
Old 01-19-2014, 11:05 PM   #4
Custom Home Builder
Rewards Points: 75
Without getting into a debate or a lot of talk...I'm simply asking what the true costs of the units are. That's it. I understand some HVAC contractors will charge more than others based on numerous variables, but that's not the question. Hopefully one of you guys can give a real answer.
Old 01-19-2014, 11:42 PM   #5
kambrooks's Avatar
Rewards Points: 572
$1000-$4000
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
Old 01-19-2014, 11:54 PM   #6
TXACguy's Avatar
Trade: HVAC
I just know you don't show your ACTUAL cost to your customers.
However, some contractors have high overheads and charge 20-60% on margin. Then 20-40% on markup for contract installers, if they have them. With Obamacare look for it to go up soon, as we have to pay a ton more for insurances.
In Texas, an inside and outside 13 SEER changeout would run around $2800-3600, depending upon location and permits, inspections and upgrades (drain alarms, horizontal or upflow, drain pans, proper code upgrades). That is just us - a small outfit! You might find it cheaper form an illegal installer.
On your bids, ask them what they are doing... itemized... If they don't or won't , find someone else.
Charlie Howe To Fix
47 years in HVAC, still learning
TXACguy is offline
The Following User Says Thank You to TXACguy For This Useful Post:
concretemasonry (01-20-2014)
Old 01-20-2014, 10:54 PM   #7
HVAC Professional
HVAC1000's Avatar
Trade: Heating and Cooling
Rewards Points: 75
I have been curious for a while about the actual cost for HVAC units. I am a builder. I have received 3 bids for a home and the range of the bids is unreal (varies up to 90% for the same units/items). I am looking for the actual (ballpark) itemized cost for a Heil and/or Goodman 13 Seer 1.5 ton AND 2 ton units only? How many hours would it take to change them out? The HVAC contractor will use the existing duct work. Thanks for your help.
. It depends. We don't even know what kind of equipment you are asking about. Is is a heat pump? Gas? Packaged? Split system? Or just replacing an A/C-no heat modification.
HVAC1000 is offline
Old 01-20-2014, 11:12 PM   #8
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Tree-fiddy?
-Steve
TimelessQuality is offline
Old 01-20-2014, 11:45 PM   #9
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Too many variables. Some jobs, one can get in & out. Others,not so much. On~line furnace dealers are pretty close to ours.
I'm not one to get crazy with fancy gear. However, being south of the Mason Dixon. Why not step it up a scoash?
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
plummen (08-08-2014)
Old 01-22-2014, 12:18 PM   #10
Gene S.'s Avatar
Trade: Plumbing, HVAC
Also consider most HVAC contractors I know have been totally screwed over by GC at least once so the price goes up with the PIA factor. Here the 13seer 2 ton condenser, coil, line set, disconnect, air handler, and misc needed parts will hit me about $2500. Now add in labor, overhead, licenses, insurance, profit, (and that PIA factor) and the price can go up pretty fast.
Gene S. is offline
Old 01-22-2014, 04:28 PM   #11
ranteso's Avatar
Trade: really?, Contractor Talk is for "Professionals"?
Rewards Points: 424
you must have just got into the business and the trades you are hiring are treating you like a homeowner.
Once you build trade relationships and trust the information you seek will be freely provided by same.
But why would you need to know? the only reason that comes to mind is to beat them up on their price, something that cheap builders and homeowners do.
ranteso is offline
The Following 4 Users Say Thank You to ranteso For This Useful Post:
CrpntrFrk (01-22-2014), Live_oak (02-02-2014), stombaugh85 (03-16-2014), tedanderson (07-12-2014)
Old 01-25-2014, 07:00 AM   #12
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,252
One contractor may pay more or less then another. based on his yearly volume. So their is no single wholesale price for any HVAC equipment.
About 13 years ago. The company at worked at then, bought about 100 units a year from the one distributor. We did a bid on a large apartment complex change out. 260 units/systems(furnce, coil, condenser) at one shot. Because all the equipment was coming at one time, the manufacturer didn't have to do production line retools. We got it at 52% of what we normally paid. Plus, for the remainer of the year, all the equipment we got from the distributor, was discounted an additional 5% off what we normally paid.
A contractor that only does 30 grand a year in equipment at a distributor pays more for the same equipment then a contractor that does 150 grand a year.
As a one man show, I don't do a large volume with anyone distributor, so I pay more then what a lot of my competition does, for the same equipment.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Old 01-29-2014, 05:41 PM   #13
Access Heating & Air
accessheating's Avatar
Trade: H.V.A.C.R.
Rewards Points: 75
The time for changing out can vary greatly between one company and another. It's no surprise that you are getting variances with that much of a spread.
Better companies and better installs=higher pricing.
The cost for equipment, especially Heil (which is such a low-qaulity brand for a custom home remodel, just sayin) can be as low as $850 and up towards $2500.
accessheating is offline
Old 01-29-2014, 07:41 PM   #14
Trade: H.v.a.c.
"....Better companies, better installs = higher pricing...." If it were only that plain and simple.
MTN REMODEL LLC (01-29-2014)
Old 01-29-2014, 08:18 PM   #15
Trade: H.V.A.C.R.
Rewards Points: 75
Yeah, if only. Hopefully you find what you are looking for and good luck getting a contractor you trust and don't have to worry about keeping his pricing low and competitive.
Boise's Best, For Over 40 Years!
http://www.accessheating.com
https://www.facebook.com/accessheating
Old 01-29-2014, 11:13 PM   #16
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
You mean higher price does not mean higher quality....
Next you're going to tell me there's no Easter Bunny or Fairy God Mother.....
GD iconoclast
Best
Peter
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 01-29-2014, 11:28 PM   #17
Trade: H.V.A.C.R.
Rewards Points: 75
Originally Posted by MTN REMODEL LLC
You mean higher price does not mean higher quality.... Next you're going to tell me there's no Easter Bunny or Fairy God Mother..... GD iconoclast Best Peter
Lol!
Old 01-29-2014, 11:54 PM   #18
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
I'll gladly itemize WHAT I'm doing, but I DON'T / WON'T itemize pricing. Ever.
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
The Following User Says Thank You to svronthmve For This Useful Post:
CarpenterSFO (01-30-2014)
Old 01-30-2014, 09:46 AM   #19
Trade: H.v.a.c.
GD iconoclast
Best
Peter
Two outfits replace an ignitor, or blower motor. One charges 25 cents and the other 50 cents. The 50 cent company does a better job of the diagnosis and installation of the part?
Sorry, if you really believe more money means better quality, you have been duped. Some companies respect the dollar more than others. Some of us try to keep expenses down for the customer, and don't hide behind the "quality cost" mask.
The Following 2 Users Say Thank You to flashheatingand For This Useful Post:
MTN REMODEL LLC (01-30-2014), plummen (08-08-2014)
Old 02-02-2014, 02:40 PM   #20
Professional Contractor
beecool's Avatar
Trade: HVACR
Should you expect to get the actual cost of a new truck at the dealer?
What is the actual cost for you to build me a 2000 sq' house?
Trade Treading Bad Question
Life Forces Us To Slow Down So We Can Enjoy It More
Get A Jump On Life And Don't Sweat the Small Stuff
beecool is offline
Cost of deck! Clemens Decks & Fencing 4 03-05-2012 08:50 PM
Dressing up a house with low cost. J-Peffer Windows, Siding and Doors 15 06-11-2008 09:37 PM
