Condensate Drain Snake - HVAC - Contractor Talk
Old 03-25-2019, 07:24 AM   #1
jpenny2385's Avatar
Rewards Points: 6
My staff and I have been using the SmartSnake for over a year now. It has reduced and in most cases eliminated callbacks. It has a stainless steel rust resistant 20' long flexible shaft, with a clearing tip. When used with a cordless drill, can chew through algae and mineral build ups. (A good quality wet vac is needed to remove debris as it is broken up.)
We have used it on drains from 3/4 " and larger
jpenny2385 is offline
Condensate Drain Question trishbk HVAC 22 06-17-2019 09:40 PM
Linear drain fail RookiePlumber Plumbing 9 12-28-2017 11:09 PM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
General Drain snake cable replacement akerplmbr Plumbing 3 12-25-2009 11:53 PM
To trap or not to trap condensate drain on a package unit? Electric_Light HVAC 6 07-25-2009 01:38 PM
