Condensate Drain Question - HVAC - Contractor Talk
Old 02-23-2015, 01:20 PM   #1
trishbk's Avatar
Rewards Points: 8
Large reno project. Installed HVAC in attic, condensate drain pipe is pvc and drains down the side of the acrylic finish. See attached photo. Anyone have issues with discoloring acrylic over time? Client concerned that this could be a future problem. Please advise. Thx
trishbk is offline
Old 02-23-2015, 02:32 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 642
Re: Condensate Drain Question
From my experience, yes it will be an issue.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
CarpenterSFO (02-27-2015), sunkist (06-15-2019)
Old 02-23-2015, 05:07 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
And the fix is to reroute this pipe?
With soft water it might not be so bad. I guess condensate qualifies as soft.
GettingBy is offline
Old 02-23-2015, 06:46 PM   #4
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
A good friend of mine might use a plumbing vent. Is there a washer box readily available?
Another option would have been to route it to the gutter's down-spout (inside, as much as possible)
http://www.37flash.com/
flashheatingand is offline
The Following User Says Thank You to flashheatingand For This Useful Post:
Tom M (02-23-2015)
Old 02-23-2015, 06:54 PM   #5
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 792
All if the new work I do they have the pipe coming out of the top of the facia and we have to cut a tiny notch in the back of the gutter and seal around it. The guy who did my central just drained it into the vent stack and haven't had any issues with it.
NYgutterguy is offline
Old 02-23-2015, 07:06 PM   #6
Tom M's Avatar
Rewards Points: 8,070
With gutters one pipe is supposed to extended over the outside of the gutter to alert the owner that the pan is overflowing.
I see lots of rust from the drains.
Tom M is offline
NYgutterguy (02-23-2015)
Old 02-24-2015, 07:49 AM   #7
GettingBy's Avatar
Yes, and I saw this once.
The HO had no idea what it meant and I recommended he get my HVAC guy to clear the condensate lines with compressed air or however he does it.
I use a garden hose or coat hanger or a snake but only on my own house.
Old 02-25-2015, 12:27 PM   #8
TWhite's Avatar
Trade: Custom Builder
Rewards Points: 608
A shop vac works good also!
TWhite is offline
Old 02-25-2015, 12:39 PM   #9
GettingBy's Avatar
And what clogs it? Dust from the air using water to clump up? When I clear it nothing comes out but yet it starts working again.
Old 02-25-2015, 12:46 PM   #10
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I get an algae based slime build up here,, usually try to dump a little bleach through it periodically to keep it at bay
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
GettingBy (02-26-2015)
Old 02-28-2015, 12:44 PM   #11
Anti-wingnut's Avatar
Rewards Points: 3,428
That's seriously how they did it? Needs to go to ground level, to a funnel drain or condensate pump.
How crappy looking
Anti-wingnut is offline
The Following 3 Users Say Thank You to Anti-wingnut For This Useful Post:
beenthere (03-01-2015), CarpenterSFO (02-28-2015), rustyjames (02-28-2015)
Old 02-28-2015, 01:04 PM   #12
CarpenterSFO's Avatar
Rewards Points: 2,044
How crappy looking
I agree. Dripping condensate down the side of a building? That's crappy all right.
- Bob
CarpenterSFO is offline
Old 02-28-2015, 01:28 PM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
The condensation that comes out of a condensing furnace is caustic enough to eat through copper pipes...
Inner10 is offline
Old 02-28-2015, 01:29 PM   #14
water re-locater
Rewards Points: 792
Found a pic of what i run into on most of the work i do as i described earlier. Going down wall like in pic if shady side of house will be one long green streak down the side of the wall for sure.
The Following User Says Thank You to NYgutterguy For This Useful Post:
Old 02-28-2015, 02:21 PM   #15
Seems like the primary suspects would be weak solutions of carbonic and nitric acid, and these would only form during the condensation of combustion products. The condensate from an AC will be comparable to the liquid entrained in air
Old 03-01-2015, 04:55 AM   #16
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,214
Thats just wrong on so many levels.
beenthere is offline
Old 03-01-2015, 07:20 AM   #17
General Contractor
greg24k's Avatar
Rewards Points: 8,478
Water will discolor everything and anything, no matter what the material is.
greg24k is offline
Old 03-01-2015, 07:22 AM   #18
TWhite's Avatar
Rewards Points: 608
In Virginia Beach the overflow (emergency) drain for the attic pan must be installed in a conspicuous location such as under the soffit, never in a location such as that which could be hidden by gutters. The main drain would be brought down through the crawl space and out about 2' to a planting bed.
TWhite is offline
Old 06-15-2019, 08:57 AM   #19
jpenny2385's Avatar
Rewards Points: 6
Constantly dealing with reoccurring clogged A/C drain lines.
www.SmartSnakes.com
jpenny2385 is offline
The Following User Says Thank You to jpenny2385 For This Useful Post:
Rio (06-15-2019)
Old 06-15-2019, 07:34 PM   #20
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Dang I see it now its a add no wonder this rave from the grave got woke up' But I did thank Grzs for a post 4 years ago good advise never gets old
Still "Shakin" the tree boss
sunkist is offline
Big Question Related to HVAC Trade - License hdung91 HVAC 3 05-29-2013 08:29 PM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
To trap or not to trap condensate drain on a package unit? Electric_Light HVAC 6 07-25-2009 01:38 PM
Floor drain question Indy_Storm Plumbing 7 04-09-2008 10:43 AM
