Hello,
Two days ago my ac stopped working, the interior unit started to rapidly drip and destroyed the laminate flooring. I used a wet dry vac to clear the condensate line which did appear to be clogged. At the same time of my ac emergency pan overflowing my hot water heater stopped working. I don't understand how the two instances could be connected but it seems to be so. My fuse box has a breaker labeled Heat, A/C, and another labeled water heater. When I switch the breaker labeled heat in the off position the whole A/C system seems to work, but when the heat breaker is switched to the on position the system entirely shuts off. My hot water heater will not turn on even if all breakers are on. I have try’d shutting the main off and back on already, and running the water for over 5 mins to ensure the water heater just didn't need time to fill up. Any responses are greatly appreciated.
Thanks in advance everyone! :thumbup:
P.S. sorry for spelling errors in heading!
