OSHA Compliant Temp Heat - Health & Safety - Contractor Talk
Old 01-24-2019, 01:52 AM   #1
Cumcaill's Avatar
I've got a real issue that I need some help/advice with....
Let me give you the background. We are a GC in NC. We build commercial buildings, multi-family, hotels. All of these contain many, sometimes a few hundred separate rooms.
How is everyone complying/applying OSHA guidelines to heat these spaces?
For those that are in the same market, what does your company is to install drywall, millwork and flooring.
We are always in a rush to get the permanent heat running but it is one of the late tasks installed. Flooring contractor are refusing more and more to put flooring in anything less than perfect conditioning. Architects cringe when wood trim is installed without permanent heat, etc.
All of these I completely understand...what to do!
Cumcaill is offline
Old 01-24-2019, 02:24 PM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 864
Re: OSHA Compliant Temp Heat
You can rent very nice temporary heating systems and there are subcontractors out there specializing in this type of work that will set up and maintain the systems.
Note that a key part of a good temp heating system is introduction of fresh air. The days of running a salamander in the building are over, it is unsafe.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Randy Bush (01-24-2019)
Thermostat sensor wire crosses heat cable freshlyd Tiling 4 04-20-2018 08:27 PM
Using electric floor heat to heat addition Stunt Carpenter General Discussion 21 04-20-2016 12:25 PM
Buddy gets a visit from Federal OSHA Calidecks Health & Safety 25 08-31-2014 08:40 PM
Munchkin Boiler heat & domestic BoulderBuilder Plumbing 14 12-02-2009 06:34 PM
heat pump jdager HVAC 2 01-31-2009 04:17 PM
