N95 Thoughts - Health & Safety - Contractor Talk
N95 Thoughts
Old 03-23-2020, 04:38 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,581
N95 Thoughts
I always felt that N95's masks were overrated, although better than nothing. Anybody else? Some brands better than others, but still....
I never could get a tight enough seal, no matter how I pinched the nose so probably ended up breathing some past the edges (dust on face shows that sometimes). Also had issues with fogging up my lenses.
Time to redesign those things, imho.
MarkJames is online now
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
greg24k (03-23-2020), rrk (03-23-2020), tgeb (Yesterday)
Old 03-23-2020, 04:44 PM   #2
TheConstruct's Avatar
Rewards Points: 1,526
Re: N95 Thoughts
I've never been able to wear safety glasses or sun glasses with dust masks, they immediately fog up. I always figured some air got around the edges, especially with my permanent stubble but it has to be significantly better than without it. That being said I can't find any masks anywhere anymore so it's irrelevant, I'm relying 100% on my lungs to filter everything out.
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
MarkJames (03-23-2020)
Old 03-23-2020, 05:23 PM   #3
rrk's Avatar
Rewards Points: 3,864
Re: N95 Thoughts
Same here I never thought they did much since they left major gaps
the fiber medical masks are very different much tighter to your moth and nose. If you wear glasses the glasses hold it closer to your face
If I need a mask I wear the full or half face with the cartridges
rrk is offline
The Following 2 Users Say Thank You to rrk For This Useful Post:
Mordekyle (03-23-2020), Tom M (Yesterday)
Old 03-23-2020, 06:11 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,190
Re: N95 Thoughts
I use the good 3M professional masks with the replaceable canisters. With my beard I need something that seal fairly well.
Randy Bush is online now
Old 03-23-2020, 06:24 PM   #5
Mordekyle's Avatar
Rewards Points: 5,734
Re: N95 Thoughts
I have a PAPR I use in nasty crawlspaces when I have to push insulation back up.
Otherwise I use a 3M half mask.
The disposable masks are pretty worthless in my opinion.
Mordekyle is online now
Old 03-23-2020, 07:09 PM   #6
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,496
Re: N95 Thoughts
N95 is what's issued to medical personnel.
My neighbor is a nurse in middle of chittfest they've been using bandannas forfuksak.
I offered to give her an extra respirator with n95 as p100 filter's. She said they wont allow anything but n95 mask... I said what about the bandanas....huh
Sent from my SM-G973U using Tapatalk
CityDecks is online now
Old 03-23-2020, 07:11 PM   #7
CityDecks's Avatar
Trade: Deck Builder
Re: N95 Thoughts
Full face is the way to go. Have any of you seen the fancy full face with air hose and some type of air pump attached. There pretty slick. Wood turners wear them
The Following User Says Thank You to CityDecks For This Useful Post:
rrk (03-23-2020)
Old 03-23-2020, 08:02 PM   #8
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,054
Re: N95 Thoughts
I use the masks that use these:
Big Johnson is online now
rrk (03-23-2020)
Old 03-23-2020, 08:17 PM   #9
CityDecks's Avatar
Trade: Deck Builder
Re: N95 Thoughts
P100 means 100% zero pass thru. N95 is 95% no pass thru. P100 is lil harder to breath thru Cleary you've adapted. P100's cover all silica lead fumes vapors chemicals just about everything. Unless you're in ito real chemicals as in chemist type of work.
Old 03-23-2020, 08:42 PM   #10
Randy Bush's Avatar
Re: N95 Thoughts
Those are what I use too.
Old 03-23-2020, 08:52 PM   #11
Re: N95 Thoughts
After doing a lot of painting (especially ceilings) when I take them off I can really tell how laboriously I had been breathing. Iíll usually just vacuum the filters then stick them back on.
Old 03-23-2020, 08:54 PM   #12
Re: N95 Thoughts
If I go up a set of stairs after they’re good and clogged I get super winded. Fun stuff.
Old 03-23-2020, 10:20 PM   #13
Mordekyle's Avatar
Re: N95 Thoughts
PAPR
Old 03-23-2020, 10:49 PM   #14
diplomat
Golden view's Avatar
Rewards Points: 1,032
Re: N95 Thoughts
Originally Posted by Mordekyle View Post
PAPR
I've been wanting one of those. Do you use one or have any details or recommendations?
Probably not something I can buy any time soon.
Golden view is offline
Old Yesterday, 05:55 AM   #15
tgeb's Avatar
Rewards Points: 612
Re: N95 Thoughts
I prefer N100 dust masks.
They seal better and don't fog up my glasses. The ones I have also have an exhale valve so they run cool. The N95's when I use them and can't see, I end up removing the mask.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
hammer7896 (Yesterday)
Old Yesterday, 06:51 AM   #16
CityDecks's Avatar
Trade: Deck Builder
Re: N95 Thoughts
Interesting. Never new they made p100 in dust mask style.
Not like I can run out and get one..
Any body try to masks? I ha vfc e not just curious. At about 30bucks it's kinda of pricey and think I would loose or never go out of my way order new filters.
Old Yesterday, 06:52 AM   #17
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 978
Re: N95 Thoughts
I can't use paper masks either, they never work great.
I've seen these ones, they look comfy enough.
https://www.jcsmithinc.com/safety-eq...ll-medium.html
NYCB is online now
Old Yesterday, 06:59 AM   #18
CityDecks's Avatar
Trade: Deck Builder
Re: N95 Thoughts
Just recently noticed that new style. Not like we can any. But I'll put it on my list.
Old Yesterday, 07:06 AM   #19
CityDecks's Avatar
Trade: Deck Builder
Re: N95 Thoughts
Just saw video on Amazon. They have a nice case to clip on / off very compact. I'm definitely getting when all this non6is over and there available.
Old Yesterday, 07:19 AM   #20
NYCB's Avatar
Rewards Points: 978
Re: N95 Thoughts
I really only keep organic vapor masks now, for sealer and other nasty stuff.
I wet cut pretty much everything and just deal with the mess, I'm so sick of dust all over the place.
NYCB is online now
